Results 1 to 10 of 11
Thread: High_Low Timing - Spark Advance (MAF).map
    Lifetime Member Tinbender59's Avatar
    Jun 2010
    Default High_Low Timing - Spark Advance (MAF).map
    I guess I just plain stupid or blind, I cannot find a tutorial for this map, can someone point me in the right direction please??
    Lifetime Member limited cv8r's Avatar
    May 2005
    What do you want to know about this map?
    Jun 2010
    What PIDS do I set up and then how do I use it??? Thanks for answering !
    May 2005
    if you open your tune file and look at the parameter you wish to log, hover the mouse pointer over the axis title/headings it will show which PIDs / parameters are associated with it, they are the PIDs you need to log to be able to gather logged data in a map. There are also pre defined maps in the scan tool
    Jun 2010
    thanks Man!!! that is so way cool!
    Also, when you log the pids that he said, you will be able to do cell highlighting in the tunetool tables from the log file.
    Nov 2014
    i seem only to have one map in maps (f11) a-j. should there be more?
    also, what does "cell highlighting" mean. how is it done? (i cant find anythig on that in the manuals.)
    Click on a map letter, and then within the same toolbar open a map... if there are none, you can create a map.
    If you log the pids listed on the axis of a tunetool table, when viewing the log, the scantool will link into the tunetool table and you can see the current operating cell highlighted, and you can watch the operating cell move around the table as the engine runs.
    Nov 2014
    thanks, i will try that.
  1. Spark being pulled all the way to minimum spark advance B5915
    By barbermi in forum Gen III V8 Specific
    Last Post: July 12th, 2014, 11:12 AM
  2. 98 350, spark advance?
    By 06bowtie_guy in forum Vortec V6/V8 Specific
    Last Post: December 7th, 2009, 09:23 PM
  3. Another Spark Advance Question
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 22nd, 2008, 04:35 AM
  4. Why so much spark advance?
    By Spdfrk1990 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2007, 07:13 AM
  5. MAP or MAF for timing
    By Dave Lewis in forum Duramax LB7
    Last Post: March 7th, 2006, 05:15 PM
