Probably not.
Nowadays it seems like everyone is all up for discussion and fishing until they find the solution, then its all "oh go fly a kite and find it yourself". I remember when we were ALL new at this stuff in late 2005 early 2006 (contrary to popular belief or what people would like us to believe, they, and myself, and everyone else in the world werent born with all this amazing knowledge of tuning)....no one was afraid to bounce ideas around and share things. What happened?
Honestly, IMO its not even worth anyone's time asking for diesel tuning help online anymore........
2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison12.9s @ 108 mph
many thanks to Ross and Paul
You also need to consider that back in the "good old days" there were only a small number of combinations to be tested to get that pot of gold at the bottom of the rainbow....now those combinations increase 10 fold or further due to the complexity and number of tables.
Is the change really a lack of sharing, or is it that not enough people have tried the possible combinations to figure out the result? Human nature is to try a few times, then as results come back negative people get disgruntled and stop. The more knock backs, the fewer people looking.....and the bigger the reward for those who do continue...
Cheers
Cindy
I will say this, I did not need anything in hex that was not yet mapped in efi live. As was stated it was not what was changed but what needed to be left alone.
I spent over 60 hours trying a ton of changes until I found what I needed to alter and what I needed to leave alone.
Think of the speed limiter, leaving certain things alone was necessary to keep the exhaust brake and or cruise control working while only having to alter certain tables.
This was by far the most frustrating thing to figure out.
Tony
Gonna have to agree with Tony on this....
These things like the minimum amount of changes possible. The more you change, the higher chance that you are gonna have problems of some sorts. Simple is better with these things.
Everything needed to do deletes is in EFI, as it turns out. But finding that correct combination is the key and the most frustrating thing. But once you figure it out, you end up kicking yourself because of how simple it is and how much you were over thinking it. The LML truely is one of those, make one SMALL change and then another small one. If those don't work, try a different approach to it. As tony said, the speed limiter is a perfect example of this kind of LML mentality.
But as it stands, the people that have had questions, I don't mind answering or helping them out, if you ask. To return the favor that was given to me.
Josh
'04 GMC LLY - L5P, Motech, 6-Spd Conv. ML Trans.
'05 GMC LLY - 250%, 12mm, 67mm Custom Turbo, 6-Spd Conv. ML Trans
'19 3500 RAM - Tuned Aisin 0_o
Cool to see you guys can do it in the software... I got it to work, but i was playing in the matrix to make it work... Now (one day) i will have to go try and make it work without the matrix tricks. Good work tony!
Yes, so far so good, no issues with anything at cold or full op/temps, set it for 10, 20, 50 doesn't matter, stays where I put.
Now redoing 2011, 2013-2014 base files and cross testing, that sucked.....but its done.
Plus the extra boost makes for better use of the traction control, that light is getting annoying fast.
