Results 1 to 4 of 4
Thread: tuning for 4l65e with dakota digital 8k
    Dec 2010
    Default tuning for 4l65e with dakota digital 8k
    Need help tuning for the dakota digital 8k pulse vss. The speed is adjusted to be close to the gps but does not shift when it needs to. It is holding gear to long? Any ideas?
    Jul 2005
    Lower your shift rpms and shift mph until it shifts where you want it to
    peace
    Hog
    Dec 2010
    Ok here's what I did to fix it. I started by manually entering 8000 for the pulses per mile and my vss was accurate but not shifting when it was supposed to. I then tried going back to stock calibrations and used the calculator and just started changing tire sizes and gear ratios until the pulses was close to 8000 and that was the ticket. Everything working great now.
    Good job
  1. LC-2: Digital Wideband, anyone try it out?
    By BlackGMC in forum External A/D inputs
    Last Post: March 19th, 2016, 12:28 PM
  2. Dakota Digital VSS
    By LS-SWAPPER in forum Conversions / Aftermarket Parts
    Last Post: December 5th, 2012, 04:02 AM
  3. 4L65E tuning and towing
    By truethinker in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 19th, 2011, 12:19 PM
  4. Help with tuning a 4L65E
    By gold-nuggets in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 9th, 2011, 10:17 PM
  5. Digital Dash
    Last Post: January 5th, 2010, 05:44 PM
