Results 1 to 3 of 3
Thread: LML Idle control not working
    Oct 2014
    Default LML Idle control not working
    I have had some issues getting these trucks to follow my idle requests.
    The one I am on now is 2011 and when it is warm it will idle at 800rpm and walk itself around a parking lot at about 8mph or higher. If you are trying to stop then it can be hard on the brakes.
    Other than Possibly A/C running (HVAC on Auto at 72* when it is 30* outside), or idling higher for EGT temps for upcoming Regen, I am out of ideas.
    Also I am wondering if anyone knows if EGT1_A PID is the turbo outlet Sensor or EGT Sensor after the Indirect (9TH) Injector.
    Thanks guys.
    2003 LB7 ECSB
    - Not Built, Intake, Mbrp Black Series 5" Straight, Banks Big Head Wastegate
    - Bagged in rear with Air Lift, 305/65/17
    - EFI Live By Myself, Used For Work
    - Sold at 242k
    2011 LML CCSB
    - Stock... For Now
    Dec 2015
    The idle in efi live is just one of many used for various situations. You'd have to decrease allll the others. Some of them are just 1 values, some of them are 3D tables.
    Jan 2017
    If you want send me the tune, and stock if you have it, I can take a look and see where you went wrong.
  1. LML vane position at idle
    By catman3126 in forum Duramax 2011+ LML / LGH
    Last Post: May 28th, 2020, 04:31 PM
  2. LML Speed Limiter changes not working
    By madmanmartin in forum Duramax 2011+ LML / LGH
    Last Post: June 30th, 2016, 05:27 AM
  3. LML Cruise control intermittant after flashing
    By shane in forum Duramax 2011+ LML / LGH
    Last Post: December 22nd, 2015, 04:15 AM
  4. Idle is working, Knock on deceleration
    By willn in forum Gen III V8 Specific
    Last Post: August 15th, 2014, 12:26 PM
  5. Working on my idle tune
    By blsnelling in forum Gen III V8 Specific
    Last Post: November 4th, 2010, 03:27 PM
