Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: LML standalone harness
    Nov 2005
    Default LML standalone harness
    Im looking to make an LML bench harness...im looking at the schematics, but wondering if anyone else could check my work.
    I saw EFI Connection's LML standalone harness, but it looks like theirs only uses 2 of the 3 connectors. In looking at the schematic, it seems like the LML harness requires all 3 connectors? Or does it? Obviously if one of the connectors has an internally bonded circuit, I would rather just leave off the 3rd connector to make the bench harness less clunky.
    C1, pin 48....ignition +12v
    C1, pin 73....ignition +12v
    C1, pin 26....ignition +12v
    C1, pin 67....battery +12v
    C1, pin 46....GMLAN -
    C1, pin 66....GMLAN +
    C2, pin 17....ground
    C2, pin 18....ground
    C2, pin 21....ground
    C2, pin 73....ground
    C3, pin 73....ground
    This is EFI Connection's harness...clearly only shows 2 connectors, I cant see which two though.
    thanks
    Ben
    12.9s @ 108 mph
    many thanks to Ross and Paul
    I only use a single connector on mine, everything you need is on the blue plug, the grounds are all internally connected so there is no need to connect the grounds on C2 and C3, just buzz them back to grounds on C1 and use those. Also, these things pull a lot of current when they first fire up!
    Nov 2005
    Alright great thanks Ross. Ill get out my multimeter and see which pins on C1 are tied to ground, and use those.
    Ive already "bench flashed" an LML ECM, but that was with an entire full engine standalone harness on the bench. I was extremely surprised at how much current it pulls at startup as well! The in-rush was every bit of ~4 amps, according to my lab-grade bench power supply.
    Ben
    12.9s @ 108 mph
    Dec 2005
    I have the EFI Live connection harness, it works fine for TIS files, Ross is correct it wants a strong power supply.
    If not the ecm will crash while flashing
    www.mscservices.net
    Dec 2005
    I have a dual 450W-15A power supply just for these picky ecm's
    The EFi Connection does not use the BLACK connector, only the Blue and Grey
    www.mscservices.net
    Nov 2005
    Are you using an ATX PC power supply Tony?
    12.9s @ 108 mph
    Dec 2005
    Yes,
    the 2001-2010 ECMs don't pull a lot of juice, but these do.
    I have them tied together so I have enough power.
    I almost thought about getting a small battery and leaving it on a minder for enough reserve amps
    www.mscservices.net
    Also when TIS reaches the end of the flash the ECM resets and if the power supply hasn't got enough juice TIS thinks the flash failed and it starts again.
    Mar 2009
    I'm guessing the large current draw would be the ECM charging the capacitors to fire the high voltage piezo injectors the LML uses?
    Yes I would say so, then it detects open circuit injectors and shuts it off.
  1. Standalone CMB849
    By cumminsDK in forum Cummins 5.9L
    Last Post: January 12th, 2017, 09:04 AM
  2. Vortec 7.4, 0411 PCM, Standalone Harness...got a ?
    By Oxyacetylene in forum Vortec V6/V8 Specific
    Last Post: March 29th, 2016, 02:33 PM
  3. LBZ standalone harness....is there any reason to keep the Class 2/J1850 wiring?
    By DURAtotheMAX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 16th, 2013, 03:59 PM
  4. Cummins Standalone?
    By wickedcummins in forum Do you want to be a Beta Tester?
    Last Post: January 12th, 2012, 02:41 AM
  5. E38 Standalone harness ?'s
    By GAMEOVER in forum E37, E38 & E67 PFI ECM's
    Last Post: October 16th, 2009, 09:29 AM
