I am trying to make a auto file into a manual file. I have located the trans type, lockout solenoid, in raw hex and corrected them. I also changed it to auto trans fitted, and corrected the reluctor tables, speedo tables, and BTM gear ratio tables. Cruise only works in gears 1-5, 6 doesn't work. Using scanner PID trans current gear it reads incorrect gear ratios. says I'm in second when I'm in first, 6th, when I'm in 5th??
If I change the rear gear ratio to a higher value, then cruise works in 6th, but gear ratios are still off, and speedo is then off. So I need to change the gear ratios.
There isn't a T42 in place, so its clearly using gear ratios stored in the PCM? Anyone know were? Even if its in raw hex, just tell me the constant for it, I can update the checksum, and work in raw hex.
