Results 21 to 30 of 31
Thread: Cax Question
  1. #21
    Dec 2012
    Or try just the . without any quotes at all.
    Quote Originally Posted by Dmaxink View Post
    ^^^Thats what I do
    Well just had a chance to try it. Kangsta's worked perfect.
    Tried it like you guys said (Ross&Kory)...
    Code:
    ;       Seg    Caption                               Major                Minor                   Vis   Dis   2D   Grp
    VIEW =    2     "Main Injection Mode Assignment"    "Injection Control"  .                         1      2    0    0
    And this is what I get
    BUT! If you write it like Kangsta suggested, it loads correctly! Table loads in the "Major" folder.
    Code:
    VIEW =    2     "Main Injection Mode Assignment"    "Injection Control"  ""                        1      2    0    0
    Thought I would test both ways, and included all that just incase something wasn't working the way it should be.
    Josh
    '04 GMC LLY
  2. #22
    Nov 2007
    I went through the same thing years ago
  3. #23
    Dec 2012
    Alright, gottttt another one!
    Is there a way to define a parameter (in this instance it happens to only be a single value), so that it is visible but can't be edited?
    There is a parameter I want to add for reference purposes only, but being it is in read only memory, make it un-editable, so its not changed by mistake. Kinda like how B1250 in the LMLs is displayed, you can view it but not change it.
    Any one have an Idea?
    Josh
    '04 GMC LLY
  4. #24
    Dec 2012
    Also, Im trying to define 32 bit map that uses floating point values...... how do I do that with the cax?
    Josh
    '04 GMC LLY
  5. #25
    Try the data type FLT.
  6. #26
    Dec 2012
    Worked perfect. Thanks a million!
    Josh
    '04 GMC LLY
  7. #27
    Jan 2014
    instead of defining an axis with hard values in a cax- is it possible to read in eeprom data and scale it for the axis data?
  8. #28
    Quote Originally Posted by RADustin View Post
    No, not that I know of.
  9. #29
    Dec 2012
    Darn... I was wondering the same thing.....
    Josh
    '04 GMC LLY
  10. #30
    Jan 2016
    is there a book or a class that teaches cax related stuff. i am a c/c++ programmer by trade so data and programming i am very comfortable with. I need help on os specific stuff in the ecm.
  1. loading in the .cax
    By RADustin in forum CAX Files
    Last Post: June 13th, 2014, 11:03 AM
  2. CAX Files.
    By MICK in forum CAX Files
    Last Post: August 28th, 2010, 12:29 PM
  3. E38 and CAX?
    By gmh308 in forum CAX Files
    Last Post: April 28th, 2009, 05:54 PM
  4. cax file?
    By myws6formula in forum CAX Files
    Last Post: December 21st, 2008, 04:00 PM
  5. .cax confusion!!!
    By Lextech in forum CAX Files
    Last Post: September 26th, 2008, 02:25 PM
