Results 11 to 20 of 31
Thread: Cax Question
    Dec 2012
    Yeah they all have a defined axis. The table on the left is the axis table for the one on the right. But I want to be able to make a change to the axis( left table) and it show the changes on the right table. If that makes sense.
    Josh
    '04 GMC LLY
    It does, but TBH I am not sure the .cax files have the ability to define that. I don't know I don't use them, I'll have to ask Paul.
    Nov 2009
    Default Cax Question
    I know I can change the axis outside of efi and efi will display what I desired on the outside within the software. I haven't tried it like this, but not a bad idea!
    -Kory
    http://www.PPEI.com/
    Dec 2012
    Yeah, I don't really have an Idea. I tried defining the Hex Address for each axis value, but that was a no go.
    If I change a table axis of a table of a EFI Defined table outside of EFI, then load it, when loaded into EFI it will show the new values, and I was sorta wanting the AXIS of the tables I define with the CAX to do the same. But I don't really think its possible or I don't know how to. but if you cant, would be a cool idea to add.
    It would be cool if you could add the AXIS tables for tables that are already defined Kory, but it won't load them saying the .cax overlaps predefined data. So I think those have to be changed outside EFI unless ross can unlock them somehow?? But tables you add yourself, you can add those axis tables. :P I kinda wanna get it setup so I only have to do all the changes in one program instead of using several and swapping between them all. haha
    Josh
    '04 GMC LLY
    Dec 2012
    Is there a way to load a cax without having to define a "Minor" folder location?
    Example:
    Code:
    ;       Seg    Caption                               Major                Minor                   Vis   Dis   2D   Grp
    VIEW =    2     "Main Injection Mode Assignment"    "Injection Control"  "Additional Parameters"   1      2    0    0
    If you don't include the "Minor" part, it screws the whole cax up, but if you put a "." it will make the folder name as such.... I just wanted to add the parameters to the "Major" Folder....
    Is this possible?
    Josh
    '04 GMC LLY
    Jan 2014
    I been wondering same stuff. It's the little things lol.
    Example:
    Code:
    Is this possible?
    Nov 2007
    from memory use a double, double quote. like ""
    What kangsta said, try an empty string (i.e. "")...
    ( I'm not sure that it will work... but let see what it does. )
  9. #19
    Or try just the . without any quotes at all.
  10. #20
    Nov 2009
    ^^^Thats what I do
    -Kory
  1. loading in the .cax
    By RADustin in forum CAX Files
    Last Post: June 13th, 2014, 10:03 AM
  2. CAX Files.
    By MICK in forum CAX Files
    Last Post: August 28th, 2010, 11:29 AM
  3. E38 and CAX?
    By gmh308 in forum CAX Files
    Last Post: April 28th, 2009, 04:54 PM
  4. cax file?
    By myws6formula in forum CAX Files
    Last Post: December 21st, 2008, 03:00 PM
  5. .cax confusion!!!
    By Lextech in forum CAX Files
    Last Post: September 26th, 2008, 01:25 PM
