Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Cax Question
    Lifetime Member Chavez91's Avatar
    Dec 2012
    Default Cax Question
    I just want to verify that if we know where the Axis Values of a EFI defined table are , that we can't load a cax file with those axis values as a table and change them?
    Example: RPMs are defined as 200,400,700,900,1000 and we want to use a cax to load that rpm axis to change it to 200,400,600,800,1000.
    Josh
    '04 GMC LLY
    - L5P, Motech, 6-Spd Conv. ML Trans.
    '05 GMC LLY - 250%, 12mm, 67mm Custom Turbo, 6-Spd Conv. ML Trans
    '19 3500 RAM - Tuned Aisin 0_o
    It depends on the ECM. Some do not have a definable axis on every table. So looking at your signature there, the LLY typically uses fixed span axis's that cannot be changed as they are hardcoded in to the OS as simple start and end range and it figures out the in-between values.
    Dec 2012
    Ahh the particular ecm I was wanting to do this on was the LML.
    Josh
    '04 GMC LLY
    Dec 2012
    When i try to define the axis values using the cax for lets say.... Injection Pulses B0552... It gives me the error saying It overlaps pre defined calibration data
    Josh
    '04 GMC LLY
    Quote Originally Posted by Chavez91 View Post
    That is because your cax defined table overlaps a predefined table.
    You can only change the axis steps of a table if the calibration has that axis defined as its own separate table.
    Ha, you know what is funny, the label on that table is wrong, Commanded Fuel and Fuel Pressure are on the wrong axis (I can't believe nobody has noticed that).
    Currently that axis is hidden from editing, I don't remember why chose to do that, I can change it so the next LML update allows you to change it.
    Dec 2012
    You got the MM3 and MPA right! Thats all that matters, right? haha There are just a few tables axis values i wanted to edit, but its not the end of the world.
    Josh
    '04 GMC LLY
    Dec 2012
    I've got a second question....
    B9005 is a table with values that I added, and B9006 is so I can edit the RPM Axis for that table. Is there a way to set up the CAX file so that when I make the change to the RPM Axis table, it changes B9005's to match? So essentially B9005 will reference the Axis values from the tune file instead of you defining static vaules in the cax.
    Josh
    '04 GMC LLY
    I don't think any of the axis tables in the LML are static, they all have a defined axis (in Bosch's madness way of doing things). Off the top of my head I won't say that is 100% correct for every table though.
  1. loading in the .cax
    By RADustin in forum CAX Files
    Last Post: June 13th, 2014, 11:03 AM
  2. CAX Files.
    By MICK in forum CAX Files
    Last Post: August 28th, 2010, 12:29 PM
  3. E38 and CAX?
    By gmh308 in forum CAX Files
    Last Post: April 28th, 2009, 05:54 PM
  4. cax file?
    By myws6formula in forum CAX Files
    Last Post: December 21st, 2008, 04:00 PM
  5. .cax confusion!!!
    By Lextech in forum CAX Files
    Last Post: September 26th, 2008, 02:25 PM
