Results 1 to 3 of 3
Thread: custom 2bar os for 2006 gmc need help.Full details inside
    Dec 2008
    Default custom 2bar os for 2006 gmc need help.Full details inside
    Ok ive got a 2006 gmc old body 1500.HAs os 12606807 and there is no custom os for this op system.So i jumped down a year to run a 12592618 were there is a 0521003 2 or 3 bar deal...Problem is no matter what i do it goes into reduced power mode and gives me a list of throttle body codes..I really dont want to do a hack maff 1bar tune on this truck...Any help would be great.
    Dec 2008
    Summary
    Supported parameters available 322
    Validated modules available 7
    System readiness test (EPA) Not checked yet
    Specifically monitored tests Not checked yet
    O2 sensors tests Not checked yet
    Diagnostic trouble codes Detected
    History freeze frames Not checked yet
    Stream-Slow scan mode Supported
    Stream-Fast scan mode Supported
    Maximum dynamic packets 16
    PCM
    System Readiness Tests Results
    Specifically Monitored Systems Tests Results
    Oxygen Sensors Tests Results
    Diagnostic Trouble Codes
    U0107 "Lost Communication With Throttle Actuator Control Module" EPA ($10) "Powertrain Control Module (PCM)"
    P0463 "Fuel Level Sensor 1 Circuit High Voltage" EPA Pending ($10) "Powertrain Control Module (PCM)"
    U0107 "Lost Communication With Throttle Actuator Control Module" EPA Pending ($10) "Powertrain Control Module (PCM)"
    P0102 "Mass Air Flow (MAF) Sensor Circuit Low" PHC ($10) "Powertrain Control Module (PCM)"
    P0463 "Fuel Level Sensor 1 Circuit High Voltage" PC ($10) "Powertrain Control Module (PCM)"
    U0107 "Lost Communication With Throttle Actuator Control Module" MPHC ($10) "Powertrain Control Module (PCM)"
    C0035 "Left Front Wheel Speed Sensor Circuit" M ($29) "Electronic Brake Control Module (EBCM)"
    C0040 "Right Front Wheel Speed Sensor Circuit" M ($29) "Electronic Brake Control Module (EBCM)"
    C0240 "Powertrain Control Module (PCM) Traction Control Not Allowed" M ($29) "Electronic Brake Control Module (EBCM)"
    C0558 "Calibration Data Not Programmed/Learned" PHC ($29) "Electronic Brake Control Module (EBCM)"
    U1016 "Lost Communications With Engine Controller - Device $10" M ($29) "Electronic Brake Control Module (EBCM)"
    History data
    this is with the 2618 in no custom os yet.put stock os back in and it runs fine,ive tried to compare all that i can and what works in the factory os has no affect on the 2618 os.
    Nov 2005
    2006+ trucks use the newer style accelerator pedal that only has two potentiometers. Along with the new pedal, 2006-2007 LS1-b trucks also have a unique TAC module to work with the new style pedal.
    I would "ASSume" that if you wanted to use the 2005 2-bar OS, you could swap out the pedal for the 2005 and older version (the one with the metal frame, pivoting pedal, and 3 potentiometers) accelerator pedal, and swap TAC modules to a 2003-2005 style....
    Ben
    12.9s @ 108 mph
    many thanks to Ross and Paul
  1. 2006 gmc yukon denali xl
    By JST in forum Petrol / Gas
    Last Post: June 25th, 2011, 01:01 PM
  2. custom pid for GM.ENGOILP ...inside... sticky info
    Last Post: December 15th, 2009, 05:57 PM
  3. Custom operating systems for 2006 models
    By dirt_track_racer_81 in forum Custom Operating Systems
    Last Post: December 20th, 2008, 03:41 PM
  4. 2006 GMC Sierra 5.3L ???
    By chatcher in forum General
    Last Post: April 12th, 2006, 01:18 PM
