Results 11 to 20 of 29
Thread: Need to replace RJ12 jack for WB Serial
  1. #11
    For anyone that is interested, the RJ12 part is:
    http://nz.mouser.com/ProductDetail/M...mybiqViA%3d%3d
  2. #12
    May 2012
  3. #13
    Thanks for posting link to source.
  4. #14
    Jan 2006
    If you can solder, then the quickest and cheapest option is to replace the jack yourself.
    Yep, I have replaced all the connectors on my V2 already, lots of plugging and unplugging over the years. Pretty straight forward on changing them but not for a novice.
  5. #15
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    Just bumping this up to the top... Paul do you have the part number for the RJ45 connector on the bottom?
    Mine has been broken forever, so I took my V2 apart and it looks super simple to replace. If I can save myself 20 minutes of going through datasheets and tracking down the right RJ45 header that would be awesome!
    Ben
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
  6. #16
    Quote Originally Posted by DURAtotheMAX View Post
    Ben
    Its GTK Connector
    CL950-8P8C-6U
    But this Molex part is equivalent from Digikey
    http://www.digikey.com/product-searc...1-2821&x=0&y=0
    0955012821-ND
  7. #17
    Nov 2005
    Its GTK Connector
    CL950-8P8C-6U
    0955012821-ND
    Hmmm both of those look to be out of stock at both digikey and Mouser. Do you know if it cross references to any other part number?
    Ben
    12.9s @ 108 mph
  8. #18
    Ben
    No sorry, that's the only reference I have.
  9. #19
    Isn't RJ45 the same as a plain ethernet jack...?
  10. #20
    Nov 2005
    Yes, but its just a matter of finding one in the proper form factor that fits the V2 case.
    Ben
    12.9s @ 108 mph
  1. Using 1/8" phono jack w/ WB for logging
    By Mr. P. in forum General
    Last Post: November 26th, 2007, 01:44 PM
  2. Can I replace my LB& with a LLY?
    By jerjoek in forum Duramax LB7
    Last Post: September 19th, 2006, 04:03 PM
  3. Replace NB w/WB or just add?
    By Garry in forum General
    Last Post: June 24th, 2006, 05:44 AM
  4. 1999 O2 replace suggestions
    By Rico in forum General (Petrol, Gas, Ethanol)
    Last Post: June 5th, 2006, 11:52 AM
  5. Replace Laptop Battery
    By GMPX in forum General (Petrol, Gas, Ethanol)
    Last Post: August 13th, 2005, 08:03 PM
