Results 1 to 4 of 4
Thread: P1404
    Default P1404
    anyone know how to defeat this? I have twin turbos(so it's blocked off) and I THINK my egr is unplugged, not sure(it's dark). Would plugging it in fool the ECM into thinking all is well? Anyone have proof that it does or doesn't hurt performance, I think it does.
    Lifetime Member McRat's Avatar
    Nov 2005
    You can check to see if it hurts performance by datalogging the Main Shot duration and comparing it to your fueling table. If you have 2900 msecs of fuel programmed for 100mm at 160kpa pressure, and you are getting a commanded value of 2200 (or other small value), something is defueling you.
    2005/2007 DHRA Western Drag Champion
    Bonneville A/DT & B/DT Land Speed Record Holder, 197mph best speed.
    Casper - 05 GMC 2500 Dmax LLY 10.59 @ 129, 916rwhp
    Big Blue - 04.5 GMC 3500SRW LLY 13.12 @ 104, 502rwhp sled puller
    Wendy - 06 GMC 2500 LBZ 12.50 @ 107.5 First LBZ into the 12's. 542rwhp.
    Blue Meanie - 02 Z06 11.40 @ 121 AFR H/C
    Lifetime Member bobo's Avatar
    Nov 2005
    Quote Originally Posted by 05lly2500hd
    It is fixed...no need to worry!
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
    Quote Originally Posted by bobo
    Yes I know now. Thanks!
