Results 1 to 5 of 5
Thread: 1999 PCM wont validate Default Metric PIDS
    Oct 2003
    Default 1999 PCM wont validate Default Metric PIDS
    Hi all!! It's been a long time since I've used EFILIVE. Many wonderful changes!! Getting back to a couple projects.
    We bought this harness and PCM From PSI Conversion (PSIConversion.com). It appears to be a 1999 PCM. It's in a 1948 Ford Pickup with a 2003 LS6 and 4l60e. I can connect read and flash the PCM. When I validate the default metric PIDs only the first four CALC PIDS validate the remaining seventeen PIDs aren't supported?? No data comes through on scanning although it does connect to the vehicle. Is it me or the PCM
    Would I be better off buying a 12200411 PCM off of ebay??
    Thanks for all and any help!
    Bink
    World Manufacturer Index 1G1 General Motors Chevrolet - USA
    Year of manufacture X 1999
    Model YY Corvette
    Engine G LS1
    Engine size G 5.7 litre V8 SFI
    Body 1 Two-Door Coupe Hardtop (27, 37, 47, 57)
    Restraints 2 Active (manual) belts w/ driver & passenger inflatable restraint system - front & side
    Plant 5 Bowling Green, KY
    Sequence 123135 123135
    VIN 1G1YY12G9X5123135
    Engine 5.7L
    Transmission Manual
    PCM flash 512KB
    Operating System 09373372
    Calibration 9374961
    OS ID BD
    Cal ID
    BCC CWMS
    OS Level
    Cal Level
    Cal file name 9373372.calz
    Cal file version 7.94
    Cal file date 07 April, 2009
    Operating System 09373372 $4D00
    Engine Calibration 16263735 $258D
    Engine Diagnostics 9357900 $0DC7
    Transmission Calibration 16264134 $71D4
    Transmission Diagnostics 16253323 $ACE7
    Fuel System 16264551 $EA4B
    System 16264766 $4B0E
    Speedometer 9359157 $0767
    Hey Bink, how's it going, good to see you back here
    Do you have FlashScan V1 or V2...?
    Which V7 software build version do you have installed (Help->About from scantool or tunetool).
    Oct 2003
    Hey joecar! It's good to be back ........I need to knock some cobwebs from my brain.
    FlashScan V2
    V7.5.7 Build 262
    Oct 2003
    I did an uninstall, fresh install 7.5.7 262. Read the pcm. Scanned and scanner says it's 2 different vehicles. Read PCM is a 2000 Corvette and scanned is a 2002 Camaro. I would guess this has to do with PS1's recalibration/ID as Corvette?? All PIDs validated ..happy camper. Car has a split personality?
    With the scantool, what does VIN say...? Is this the correct VIN...? Try setting the VIN again using the scantool.
  1. Calc.vet on 1999 5.3 Silverado: dynamic air temp will not validate?
    By thunderstruck507 in forum Gen III V8 Specific
    Last Post: July 31st, 2014, 12:08 PM
  2. PIDs won't validate with V1
    By ferocity02 in forum General
    Last Post: June 3rd, 2013, 03:26 AM
  3. cant validate rafig pids
    By rpmauto in forum General (Petrol, Gas, Ethanol)
    Last Post: April 2nd, 2010, 04:58 AM
  4. Can't Validate ETC PIDs
    By DrX in forum General
    Last Post: January 18th, 2010, 01:52 PM
  5. Can't get Boost PIDs to Validate??
    By 06bowtie_guy in forum Diesel
    Last Post: March 18th, 2007, 04:25 AM
