Results 1 to 6 of 6
Thread: Please someone help me 9360361 with a 4l80e segment.
Hybrid View
    Aug 2014
    Unhappy Please someone help me 9360361 with a 4l80e segment.
    Can someone please help me. I have a 4l80e swap and have to change to an os with a 4180e segment. I can not find any infromation on how to swap OS's please someone point me in the right direction.
    My os is 9360361
    Easiest path will be to upgrade to an 02 OS and seg swap an 80E segment in.
    To upgrade OSs, go to TuneFileDepot.com and download the 1999 Camaro tune that has the blue I next to it, 1 is auto 1 is manual. It is an 02 OS with all the 99 values in. Download an 02 truck OS with the 4L80E and seg swap the 80E trans and trans diagnostics segments in.
    Then copy or script your tune into the engine part, the trans tune will need to be redone. Full flash the tune into your PCM and repin as necessary to run the 80E.
    Aug 2014
    Thank you for your help. You nailed it for me.
    Feb 2014
    can anyone hep me with a 2006 gmc 4.8 sierra trans segment swap from auto to manual , there are no files in the depot , need help asap need file done today
    thanks jim
    or how i send it in for the swap
    found this file not sure if its compatible , i thought gm used the nv3500 in the light duty trucks up to 2006
    Jul 2012
    Old thread, but I am in need of a 4L80e segment for this OS as well. We are dealing with a modified 5.3/4l60e that was previouly tuned, it now has a trans swap. I would really like to just swap the trans segment, the vehicle isn't in house to retune with a different OS. Thanks.
    Jul 2012
    Bump, anybody?
  1. Need blackbox 4L80E tune for my 4L80E segment swap
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 10th, 2013, 10:57 AM
  2. did segment swap to 4l80e have a question
    By Cool28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 3rd, 2011, 11:42 AM
  3. 4L80E segment for OS 09379910
    By vortecyota in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 19th, 2010, 12:05 AM
  4. 4l80e segment swap!!!
    By hyderm87 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 14th, 2009, 03:28 PM
  5. 4l80e segment swap!!!
    By hyderm87 in forum Custom Operating Systems
    Last Post: May 12th, 2009, 03:29 AM
