Results 1 to 2 of 2
Thread: GM.FTC - Is VSS needed for this? AutoVE filter FTC 21
    Apr 2014
    Default GM.FTC - Is VSS needed for this? AutoVE filter FTC 21
    I was reviewing the Autove tuning and some use a filter for FTC 21. Is the VSS signal needed for the computer to "see" decel and flag it as FTC 21?
    I do not have a VSS signal available at the moment.
    I believe my ecu/datalog is not flagging it and causing the decel values to be averaged into the BEN factor.
    What do you guys think?
    thanks
    You should be able to use TP to detect decel.
  1. Replies: 32
    Last Post: June 24th, 2010, 06:21 AM
  2. AutoVE filter
    Last Post: October 5th, 2009, 04:00 AM
  3. FTC Numbers
    By white2000ta in forum General
    Last Post: January 8th, 2008, 05:19 AM
  4. AutoVE MAF calibration clarification needed
    Last Post: August 25th, 2006, 10:20 PM
  5. FTC 70 and 71 ??? Huh ?
    By J 98ta in forum General
    Last Post: June 13th, 2005, 12:56 PM
