OK since the instructions in the V7.5 manual do not come close to what I finally found, and I did get "I think" a good relearn. at 4700 the motor hiccuped then dropped out. see Case JPG. now according to the hotkeys section in the scan manual "shift,ctrl, F8" does not display the learned angle??? I am trying to verify that I am at "0" degrees before I start the tuning process. I am not having any luck finding it???
I found out that I had a bad Cap and Rotor, which I am assuming that this would skew my data, as such I created a "from scratch" tune using the Savanna and Corvette tunes. It runs and idle's real good, although the timing maps need a little work I did run a spark timing map "attached" It appears too have a hot spot, lol
also I have not figured out how to upload pid's to my V2, but in the process of trying to figure it out I wiped all of my controllers in the V2. and can't figure out how to reload them. I am trying to get there!!! lol
Is there a manual that is closer to what I am working with???
