Same situation here! Looking forward to the fix.Originally Posted by BigTex
Have you tried clearing the DTC codes through the DIC ?Originally Posted by curtbriggs
Sent info. Hope it helps some.Originally Posted by bink
joel
No, I didn't use the DIC, good point though, might help trouble shoot Flashscan. I'll try that next time the codes come back.Originally Posted by SS-1500
Curt
99C5, mn6, Vortec T trim, Snow meth injection, AFR 205s, ARP studs,Comp 224*112*+2*.580", YellaTerra RRs, PRC Ti's w/dbls, Supermaxx LTs, No Cats, Corsa Indys, LS6Intk, Hurst, Fikse Aro18"s. Pilot Sports 315/30,265/35, 04ZO6 Shocks Hotchkis bars, EBC YellowStuff pads, SS hoses, LM-1, EFILive, 2002 OS. RPS dual disc Clutch, DTE Strut Brace & output shaft.
A patch is being tested internally right now.
As soon as that patch get's the green-light, I'll make it available for limited release - to those that have posted in this thread.
Originally Posted by Blacky
Thank you.
joel
Just like this << ran into a similar problem today after flashing a new program into the pcm. Some how it tripped the security and would not let the truck start. The code it was throwing had to do with fuel shut off security i dont remember the exact code number. I flashed and reflashed and still would throw the same security code.>>
Clearing DTC made no difference. Sending the BCM reconnect did not work. Disconnect the battery and reconnect, it worked and started up. Hmmmmmsounds like windows 95....crashes and you have to reboot .
And this actually occured on a READ operation.
Robert
LS12 Edit Veteran
I had the no start problem after reading the PCM on a 2002 Silverado as a result of the bug that resulted in a P1626 code, which I was unable to clear. I reflashed the PCM with Edit and that eliminated the problem. I also read the PCM in a 2003 H2 and had no problems. I've notified Paul of the problem and I'm just adding this note for informational purposes. Just as an aside to hopefully prevent any typical internet bad-mouthing-- this bug is just a bug. The systems in LS1/LS6-powered vehicles are relatively complex and EFILive is one of the most sophisticated tuning/scanning tools available. Put the two together, and it's virtually impossible to anticipate every potential problem. The guys at EFILive are VERY responsive to user input, which is one of the reasons their product is so good.
2000 C5 here and it goes to "reduced power" after flash (altough it runs fine, and cannot be cleared. If I disconnect + bat term and touch to - term then hook it back up, all is fine again.
PowrMax Performance
100 mm PowrMAF
Also, had “Reduced Power” message, but the flash seemed to work fine. Once completed, I went directly into reading the codes through the DIC. Only 1 of any value was found P1518. I cleared the codes once I completed reading them. Turned the key off and waited at least 30 seconds. Car started right up with no check engine light. Good to go. Now if I could only figure out how to resolve my LTFT issues. Got some reading to do.Originally Posted by Bruce Melton
