Results 1 to 3 of 3
Thread: engine monitoring 2006 gmc yukon xl denali
    Aug 2012
    Default engine monitoring 2006 gmc yukon xl denali
    i have EFI live full v2, i also have a 2006 gmc yukon xl denali, the oil pressure gauge pegs to 80 when i turn it on, i want to watch the oil pressure using efi live if possible, to compare gauge reading and actual output from sensor, is this possible?
    any help appreciated, just got the vehicle in question
    2005 GMC 2500HD Duramax Diesel
    2011 Ford Explorer (wifes rig)
    1974 GMC Sierra Grande
    2007 Arctic Cat F8 Sno Pro
    The oil pressure gauge pegging during engine start is a function of the IPC...
    EFILive can edit only the PCM/ECM/TCM and not any of the other vehicle modules.
    Aug 2012
    I didn't want to edit anything, just watch the real time oil pressure reading coming from the sensor, to make sure its the gauge before I send the IPC out.
    I'm just thinking if the oil pressure sending unit is bad, it could be sending a reading of 80 lbs right when its turned out. My logic may not be correct, but that's what I'm thinking,
  1. Replies: 3
    Last Post: August 17th, 2013, 02:44 PM
  2. 2006 gmc yukon denali xl
    By JST in forum Petrol / Gas
    Last Post: June 25th, 2011, 01:01 PM
  3. EBCM setup / '03 Yukon Denali
    By Boost in forum Gen III V8 Specific
    Last Post: December 17th, 2009, 05:03 AM
  4. Anyone Have A Tune 04 Gmc Yukon 5.3?
    By turboolds in forum Gen III V8 Specific
    Last Post: September 21st, 2008, 07:03 AM
  5. Gmc Yukon Immo
    By car_tech4 in forum Gen III V8 Specific
    Last Post: November 19th, 2006, 03:24 PM
