Results 1 to 2 of 2
Thread: Truck vs C&C Compatibility?
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default Truck vs C&C Compatibility?
    Hey guys,
    Two questions, both on the same premise....
    1) Can you flash a manual trans OS from a pickup into a manual trans C&C, assuming you increase the fuel pressure to match that required by the cab and chassis? Reason being, I need to get rid of the chime for a customer.
    2) Based on the same idea and reasons above, can the same be done flashing an auto (68rfe) file from a truck into and Aisin auto equipped C&C? Will this mess up the communication with the Aisin or anything else? Again, to beat the chime on the C&C
    Thanks for any input
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Nope. C&C files must be used in the C&C.
    Dan's Diesel Performance
    www.dansdieselperformance.com
  1. Replies: 9
    Last Post: May 7th, 2013, 04:03 PM
  2. Replies: 2
    Last Post: July 12th, 2011, 05:08 AM
  3. Compatibility
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: December 18th, 2008, 11:53 AM
  4. EFI LIVE & HPTUNERS compatibility?
    By Rich Z in forum General (Petrol, Gas, Ethanol)
    Last Post: January 1st, 2008, 10:46 AM
