Results 1 to 3 of 3
Thread: 0411 swap Knock Sensor??
    Jan 2013
    Default 0411 swap Knock Sensor??
    I have swapped an 0411 in my wife's 97 zr2 S-10 4.3. The motor is stock and I have been logging a lot of knock around cruise with a stock 2002 blazer tune. I then realized the blazer had the flat response type sensor and her 97 s-10 has a resonant 1 wire sensor.
    I don't have any stock 4.3 files with resonant calibrations. I swapped all the knock sensor tables from a 2002 express van 5.7. Will this be sufficient or is there a better way.
    She drives her truck on the interstate every day to and from work cruising about 70-75 right in the area I was picking up knock. I could hear an audible amount of knock before I changed the knock tables. While this fixed the knock i could hear I was still picking up knock and could feel the PCM pull timing at certain points.
    I have logged and adjusted the spark tables as needed to stop the knock but the cruise areas are about 3 or 4 degrees below stock in some areas, is this normal? I am tuning for best economy at cruise and need to get this sorted out before I start leaning things out.
    Thanks!
    Jan 2013
    I should also add her truck is lifted on 33's with 3.73 gears so a little more strain than stock but relative to pulling a small trailer.
    Mar 2009
    Weird, my truck experienced the opposite phenomenon to a degree. It had a high RPM/high load phantom knock with the blackbox but now gobbles up advance with the 411 without changing knock sensors. It pulls that much harder now too. I know on the V8s that knock sensor swapping isn't required. I'm not sure about the V6 camp though, perhaps now that the 411 is in place you should swap a V8 in there for it to control.
  1. 0411 swap on 99 Vortec 454
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 22nd, 2013, 11:49 AM
  2. 0411 Swap, O2 sensor wiring is different
    By nevinsb in forum Gen III V8 Specific
    Last Post: September 2nd, 2012, 01:36 AM
  3. 0411 Swap???'s
    By GAMEOVER in forum Vortec V6/V8 Specific
    Last Post: May 24th, 2011, 01:25 PM
  4. 0411 swap w/ one wire knock?
    By chevy052500hd in forum Gen III V8 Specific
    Last Post: July 13th, 2009, 01:50 AM
  5. 0411 Swap, Tach is off
    Last Post: August 29th, 2008, 10:04 AM
