Results 1 to 10 of 11
Thread: Engine Oil Temp on LS1B
    Jun 2014
    Default Engine Oil Temp on LS1B
    Can oil temp be logged on an LS1B?
    The car is a 2000 Corvette w/manual transmission?
    Log GM.EOPS (volts) and CALC.EOP (psi)
    It is only valid on vehicles that have the EOPS wired to the PCM (not the IPC), i.e. Corvette.
    Jun 2014
    Isn't EOPS for Pressure? I'm looking for Temperature.
    Ah, sorry, my bad, I was speed-reading...
    The standard Corvette does not have an engine oil temp sensor.
    Jun 2014
    I can display oil temperature on the driver info center (DIC). I found this a while ago (don't remember where) but being an EFIlive newbie it doesn't mean anything to me:
    GM Oil Temp: set up custom PID 221154, unit C, max/min 215/-40, equation A-40. It's not exactly correct but it's usually within 5-10 degrees on my DIC. I think this is part of the GM extended PID set that you can access thru the Torque main menu.
    I'll take a closer look at the 2000 Y-car wiring diagrams... it might be a function of the IPC... but we'll see what I find.
    Jun 2014
    I took a look through the factory repair manuals. They show the engine oil temp sensor connected directly to the instrument cluster. It does talk about connecting a scan tool to observe the oil temp parameter in the IPC data list.
    I saw that...
    since the EFILive scantool logs pids from the PCM only, you wont be able to see the engine oil temp pid.
    Jun 2014
    Bummer.
    Thanks!
    Oct 2003
    Hmmm....I need to check this on the LS6 setup - old school analog gauges. Thanks!!!
    ummmm oops Corvette engine, Camaro PCM.
  1. Engine oil pressure
    By sinr98 in forum Gen III V8 Specific
    Last Post: August 18th, 2010, 05:43 AM
  2. Logging Resistance Based Values - IE Oil Temp Sensor
    By Jasondt2001 in forum External A/D inputs
    Last Post: June 21st, 2009, 11:20 AM
  3. Current Gear and Oil Temp
    By kwhiteside in forum FlashScan V2 BB Logging
    Last Post: June 21st, 2009, 08:28 AM
  4. Oil Temp Acceptable Range
    By bobbycollier in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 20th, 2009, 02:45 PM
  5. Reading oil pressure and fuel temp on a LBZ
    By Jasondt2001 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 11th, 2008, 09:29 PM
