Both the V7.5 and V8 software was updated in this release, you must update both software packages.
Release Notes:
Known Issues:Check for known issues
here.
The V7.5 software link above was updated on Sep 19 2014 to fix the *.czx file problem described in Known issue #3.
The V7.5 software link above was updated again on Sep 20 2014 to fix additional *.czx file problems described in Known issue #3.
Please download and re-install the V7.5.7 (build 266) software if you have not already done so.
Please post new issues, questions or clarifications (large or small) in this thread.
As new issues are verified they will be posted in the "known issues" thread above.
Version Numbers:
After installing the latest release you should have the following software, boot block, firmware versions installed:
EFILive V7 software: V7.5.7 Build 266
To view the installed version, select Help->About (in the V7 Scan or Tune software).
EFILive V8 software: V8.2.2 Build 260
To view the installed version, select Help->About (in the V8 Scan and Tune software).
Boot Block: V2.07.07 (Feb 07, 2014)
To view/update the Boot Block, Click the [Check Firmware] button in the V8 Scan and Tune software.
Firmware: V2.07.66 (Sep 12, 2014)
The EFILive Development Team
