Page 1 of 7 123 ... LastLast
Results 1 to 10 of 67
Thread: Update: Sep 12, 2014
    Default Update: Sep 12, 2014
    Please download and install both the V7.5 and V8 software packages.
    Both the V7.5 and V8 software was updated in this release, you must update both software packages.
    Release Notes:
    Known Issues:
    Check for known issues here.
    The V7.5 software link above was updated on Sep 19 2014 to fix the *.czx file problem described in Known issue #3.
    The V7.5 software link above was updated again on Sep 20 2014 to fix additional *.czx file problems described in Known issue #3.
    Please download and re-install the V7.5.7 (build 266) software if you have not already done so.
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the "known issues" thread above.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 266
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 260
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Boot Block, Click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.66 (Sep 12
    , 2014)
    The EFILive Development Team
    Thanks Paul.
    Lifetime Member Chavez91's Avatar
    Dec 2012
    If I load a OS that has a cax file that loads with it. Then in the same session, click open, and try to load a different file (does no matter what it is or what OS) it will give me a "PCM unrecognized" message and not load any parameters.
    Verified this on 2 PCs.
    Thanks for the Update tho!
    Josh
    '04 GMC LLY
    - L5P, Motech, 6-Spd Conv. ML Trans.
    '05 GMC LLY - 250%, 12mm, 67mm Custom Turbo, 6-Spd Conv. ML Trans
    '19 3500 RAM - Tuned Aisin 0_o
    Dec 2012
    Also, the labels on table B0552 on the LML OS's. Fuel Pressure is with MM3 and Commanded Fuel is with PSI
    Josh
    '04 GMC LLY
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    Is it just me or does the "release notes" link not work?
    Quote Originally Posted by comnrailpwr View Post
    Its working for me
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Works for me.
    Jun 2011
    Humm, probably because im on my phone with taptalk.
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    When I open the Scan & Tune Tool it says Build 259 not 260 as the first post states.
    Member jay p's Avatar
    Dec 2005
    I also get build 259 for Scan & Tune. The install file says 260, but 259 is installed.
    2019 Sierra 6.2l
    2017 2500HD L5P
    2010 2500HD LMM (sold)
    2005 Harley Ultra Classic
  1. Known issues with Sep 12, 2014 release of the EFILive software and firmware.
    Last Post: September 26th, 2014, 04:43 AM
  2. Update: Jul 04, 2014
    Last Post: July 8th, 2014, 09:56 AM
  3. Update: Jun 16, 2014
    Last Post: June 20th, 2014, 02:51 PM
  4. Update:Sep 25, 2013
    Last Post: October 15th, 2013, 03:03 PM
