Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 67
Thread: Update: Sep 12, 2014
  1. #21
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Does this build have the beta version of the "anti tune" fix for the CMC? if so I have a customer that could benefit from that today, otherwise I'll have to ship him a smarty for now. Thanks
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
  2. #22
    Jan 2006
    Speedometer segments in E38 trucks seem to have different values in them. When looking at the history of a tune I already done the values dont match whats shown. Both tunes in imperial speedometer settings.
  3. #23
    Nov 2005
    Quote Originally Posted by LBZoom View Post
    No it doesn't. But send me an email, and let me know if your running this pre-release or July software and I can send you the files.
    Email Cindy at EFILive dot com
    Cheers
    Cindy
  4. #24
    Quote Originally Posted by minytrker View Post
    Can you please give specific examples, E38 calibrations should not have changed.
  5. #25
    A known issue with the V7.5 tune tool editor software has been confirmed. If you attempt to open a tune file that uses a *.cax (user defined calibration definition) then the editor will not load the EFILive defined or user defined calibrations correctly. Current workaround is to rename the *.cax file so that it does not get loaded. We are working on a fix and hope to issue an update in the next 24 hours.
  6. #26
    Lifetime Member Chavez91's Avatar
    Dec 2012
    We are trying to figure out an issue with a $0502 code on an autocal using this update. We are trying to flash a E86B controller. And I tried resetting it up several times, but we keep getting the same error.
    The only thing that I can think of is maybe it is missing a file in the install for it? Here is the file list that we currently have loaded on the autocal.
    The only thing that stands out is that it is missing a E86B_F.obj?
    I tried looking for the file in "C:\Program Files (x86)\EfiLive\V8\Config" but no E86B_F.obj. I resaved the file using the new updated v8 software. No avail.
    I only included the E86A ecm because i thought maybe it would help. but no... Tried clearing config system and reprogramming the config files using V8, under BBX, F3: Tune, selecting the E86B controller and choosing "Program selections and configuration files (slower)" Nope.... Get the same list as above and the $0502.
    Ill include a copy of the options.txt
    Options.txt
    Josh
    '04 GMC LLY
    - L5P, Motech, 6-Spd Conv. ML Trans.
    '05 GMC LLY - 250%, 12mm, 67mm Custom Turbo, 6-Spd Conv. ML Trans
    '19 3500 RAM - Tuned Aisin 0_o
  7. #27
    Dec 2005
    Got to the V8 Scan Tune program, BBX - F5 then the "Tune" tab use the green "+" and add the E86B controller by right clicking add controller
    www.mscservices.net
  8. #28
    Dec 2012
    Still a no go. Here is how that screen is setup.
    I deleted it then re added it, and hit the "Program Selections and configuration files (slower)"
    Same error
    Josh
    '04 GMC LLY
  9. #29
    Dec 2005
    Format the File System then reprogram it
    www.mscservices.net
  10. #30
    Dec 2012
    Formatted Data & Config systems using EFILive explorer. Copied over all the tunes 1 CTZ file for the full flash and 4 COZ. All were re-saved using 8.2.2.260. Choosing the " Save, For AutoCal" option under the Save Button.
    Then created a fresh options.txt. Set it up like so.
    These are the files that were copied over.
    Still $0502.....
    BootBlock is 2.07.07 Feb 07, 2014
    Firmware is 2.07.66 Sep 12, 2014
    Josh
    '04 GMC LLY
  1. Known issues with Sep 12, 2014 release of the EFILive software and firmware.
    Last Post: September 26th, 2014, 04:43 AM
  2. Update: Jul 04, 2014
    Last Post: July 8th, 2014, 09:56 AM
  3. Update: Jun 16, 2014
    Last Post: June 20th, 2014, 02:51 PM
  4. Update:Sep 25, 2013
    Last Post: October 15th, 2013, 03:03 PM
