Results 1 to 2 of 2
Thread: $0322 Error
    Lifetime Member darcy's Avatar
    Feb 2012
    Default $0322 Error
    I'm having some problems with my 1Mb PCM (12586243)
    If I try to flash it with v8, I get the following error:
    If flashing with v7, the error is:
    Background as follows:
    Vehicle is a '05 Holden Crewman.
    I have successfully flashed this many times (100+) before. The last flash also seem to complete without issue. In the last calibration, I did make a change to one of the ECT parameters ({B2713} ETC Max Position for Idle) - hoping that I have not bricked the PCM....
    Software details:
    v8.2.2 Build 258
    Bootblock 2.0.07
    Firmware 2.07.63
    v7.5.7 Build 261
    Have tried ticking the 'assume lock is faulty' check box, but no difference in outcome.
    Any insight, or additional steps to take are appreciated.
    Cheers
    Mark
    Hey Mark, thanks posting the supporting info... I'll pm Paul.
  1. Replies: 8
    Last Post: March 20th, 2018, 06:47 AM
  2. Error $0322 kodiak 4500
    By Rstowe in forum FlashScan V2
    Last Post: August 7th, 2014, 03:58 PM
  3. I can't use V8 because of this error
    By odd boy in forum FlashScan V2
    Last Post: October 2nd, 2013, 08:56 AM
  4. Getting codes $0322, $0312 Need Help!
    By toloud4u28 in forum FlashScan V2
    Last Post: October 31st, 2010, 02:46 PM
