Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: LS6 4L60e 1948 Ford Pickup LTFTs 25+ @ Idle
    Oct 2003
    Thanks for the follow up... so the Edelbrock TB was letting too much air thru during idle.
    Yes, the Edelbrock was letting way to much airflow through!! I cleaned the rest up with using the MAFFEQ as you suggested. Thanks joecar!!
    joel
    May 2012
    What shift point are you using on that LS6 4L60e?? i have the same combo, but im unsure what shift point to use
    Jul 2003
    Brake cleaner and looking at the o2 millivolts is the best way to find air leaks.
    8 Year old thread Bump?
    +1.
    Quote Originally Posted by nonnieselman View Post
    Yes... the info posted by Highlander may be late, but it is a very good method to detect air leaks (you can localize the brake/maf cleaner using the red straw that comes with).
  1. Need help with LS1/4L60e tune, bad idle
    By LS-SWAPPER in forum Gen III V8 Specific
    Last Post: September 1st, 2015, 12:05 AM
  2. Idle speed for LS6 cam
    By aaronr in forum Petrol / Gas
    Last Post: July 7th, 2010, 02:23 AM
  3. Replumbing the PCV pickup point
    By joecar in forum Tips and tricks
    Last Post: March 1st, 2006, 04:07 PM
  4. My LTFTs maxed out at idle!
    By johnsZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 6th, 2005, 03:16 PM
