Results 1 to 3 of 3
Thread: Power at rear wheels on scan log
    Junior Member longcummins's Avatar
    Feb 2013
    Default Power at rear wheels on scan log
    How accurate is this feature in the scan function on V-8 scan tool? Is it similar to to the boost reading and it limited to what a sensor is able to register? Just curious what other have experienced thanks. I dont have a dyno close that I am aware of so just trying to see how accurate the info I log can be. Thanks
    467.7 FMW Stainless Diesel
    Which pid are you referring to...?
    Feb 2013
    (CALCPOWER) Power at rear wheels and it right below percentage of torque, also I was wrong it is not the V8 portion its in the scan tool log feature. V 7.5
  1. how to get reading out of HP at rear wheels PID
    By Chevyboy2004 in forum Diesel
    Last Post: August 17th, 2008, 02:54 PM
  2. Power at rear wheels PID
    By tazinhawaii in forum General (Petrol, Gas, Ethanol)
    Last Post: August 4th, 2008, 04:14 PM
  3. rear axle max torque and rear prop shaft numbers
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: June 17th, 2006, 04:10 PM
  4. power at rear wheels pid
    Last Post: May 4th, 2006, 03:21 PM
  5. Replies: 3
    Last Post: October 6th, 2005, 06:21 PM
