Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: IAC steps very high.
    Jul 2009
    Default IAC steps very high.
    Alright, so I have been doing a bunch of reading and most people are saying, even with a cammed engine I should have about 50-60 steps on the IAC at idle.
    I am seeing about 120-150 steps. If I force anything less with DVT, the engine immediately dies. What could cause this? I know I have a larger cam, but I have seen guys with larger or equal cams to me and they aren't this high on IAC steps.
    Cam is Comp 230/238 .600 .603 @ 114.
    Any ideas from latest logs?
    Log_0011.efi
    Log_0010.efi
    Apr 2008
    What intake and throttle body are you running?
    Jul 2009
    Stock truck intake and stock 78mm TB.
    You'll have to adjust the TB open some more in order to lower the IAC steps.
    Jul 2009
    I am in a 2000 Silverado. It doesn't really have a TB adjustment. It is a DBW.
    Lifetime Member picnic_george's Avatar
    Jan 2007
    If it's DBW there is no IAC hence no IAC steps to count.
    I don't think 2000 silverados came DBW????
    Aug 2010
    Some pre-2003 Trucks were DBW. If it is a 2000 model, then it probably uses OS12205612.
    Take a look at the idle airflow values - generally these need to be increased slightly with a larger (non-OEM) camshaft. Start with B4307 and B4308 - then look at the corrections parameters if you are still having issues.
    Jul 2009
    Sorry guys, it is DBC. My bad. I have got the idle airflow values to where it idles perfectly driving and cruising, but I am still at 150+ on steps.
    Here is latest log and tune.
    Sleeperado v1.0.ctz
    Log_Drive.efi
    Lifetime Member johnv's Avatar
    Jan 2005
    If it drives and idles fine, leave it alone.
    If not crack the throttle stop open until counts are down around 30-50, be careful not to go too far or TPS volts may go out of range, (you may have to do a TPS reset) .
    Then log and adjust Running airflow again.
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
    Apr 2008
    I agree if it runs and drives fine. Leave it alone. Don't get to caught up in the counts.
  1. IAC steps??
    Last Post: August 31st, 2008, 10:38 PM
  2. IAC Steps and near stalling....
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: June 10th, 2008, 01:06 PM
  3. how bad is 140 IAC steps?
    By gcross in forum Gen III V8 Specific
    Last Post: January 29th, 2007, 07:15 AM
  4. IAC steps.
    By Big Kahuna in forum General (Petrol, Gas, Ethanol)
    Last Post: January 9th, 2007, 11:16 AM
  5. IAC vs IAC EA vs steps
    Last Post: March 23rd, 2006, 04:54 PM
