Results 1 to 5 of 5
Thread: Gen 3 5.3L ON3 turbo, my first turbo tune, any help
    May 2012
    Default Gen 3 5.3L ON3 turbo, my first turbo tune, any help
    im working on a XJ cherokee, with a 5.3L/4L60 .. this is my first turbo tune so any help will be great, its my own truck
    -Engine is completely stock
    -Transmission is a 4L60E i got it from monster transmission
    -turbo is a On3 76mm turbo
    -3Bar map sensor ( im runing this one because i already have it and maybe will add more boost later)
    Fuel system:
    -Stock return type fuel rails
    -Ford lightning green injectors
    -Walbro 255 intank fuel pump
    PLANING TO RUN 8-10 PSI of boost
    As this car will be used as offroad, i want it to keep it simpler so i want to run it in custom OS Speed density, in Open Loop, ( No o2s sensors)
    Im working on a 2003 truck tune as a BASE..
    changued the C6301 to 283.5 , Key on engine off shows 101, it has to show that right?
    The other question is about the injectors; i look for the flow rates, on a ford forum they say they are: the lime-green ford lightning(ford motorsport) SVT M112 are 440cc@3.0bar , using this info and the injectors.xls, it shows me : 6.2987 , is that a correct flow rate for this injectors?
    May 2012
    i found that the injectors flow rate at 58 PSI is: 6.1108
    MY MAP looks to be measuring right
    does my starting base tune looks sane??
    ill be using LM1 wideband, will work on both VE tables. i will start playing with timing then.. does this looks ok? or im totally lost?
    May 2012
    started the truck, it looks to be working right, idles normal, i changued the values on B3647 and B3649, think im going to control fuel with Power Enrichment..
    Quote Originally Posted by 400ss View Post
    I calculated 6.1 g/s to 6.2 g/s (depending on the density of gasoline).
    I'll take a closer look at your file (I've been swamped in the last couple of weeks and I'm slowly catching up).
    May 2012
    THank you very much, really..
    I used 6.1094, started the truck and it idles nice and revs ok too.. next step i will install the cold side piping to start tuning VE tables.
    want to push 10psi but will see if the fuel pump provides enough fuel
  1. turbo tune
    By vcls1 in forum Gen III V8 Specific
    Last Post: December 11th, 2012, 02:01 AM
  2. turbo tune
    By vcls1 in forum Gen IV V8 Specific
    Last Post: June 12th, 2012, 03:19 PM
  3. Need a Twin Turbo Tune
    By mackattack in forum Duramax LB7
    Last Post: April 20th, 2011, 01:30 AM
  4. Need Help w/ 6.0 Turbo Tune
    By GAMEOVER in forum General (Petrol, Gas, Ethanol)
    Last Post: October 9th, 2009, 03:01 PM
  5. Closing turbo vanes for turbo braking?
    By Haulinbass02 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 14th, 2009, 12:12 PM
