Results 1 to 5 of 5
Thread: can someone look at my tune please? timing and fueling issue
    Senior Member JUSTASBC's Avatar
    Aug 2010
    Default can someone look at my tune please? timing and fueling issue
    I have a couple questions that I can not figure out. I am working with the truck in my sig. I recently switched to Injector Dynamics id1300 injectors. I installed the data from ID, and they seem to be working real well. The reason I went with the id1300's is that they are designed to be used with different fuels such as E85, and pump gas. E85 is not that readily available in my area, so I figured I would drive on the street on pump gas, and switch to E85 to go to the track. Today I put in about 30% ethanol, and it ran real lean. The sensor appears to be working properly for the amount of ethanol I put in. I can correct this by adjusting B3601 from 0=14.68 to 100=3 and filling the cells in with linear data. I just know this is not the proper way to correct this, and I can not figure out how to correct this properly. Or is this the best way to do this?
    I also have a question about timing. My timing seems to be bouncing between 13, and 16.5 at WOT. I am not sure what is causing this, there must be something in the tune that I have overlooked. I go WOT around frame 580.
    Any help is appreciated.
    Daryl
    Flex Fuel.ctzWOT timing frame 580.efi
    05 Joe Gibbs black RCSB ram air hood, Leer tonneau, blacked out tail and head lights. Forged 370, Eagle crank, Wiseco pistons, Compstar Rods, Pro Flo XT intake, KB Racing log, spool valve, T6 S480 1.32 A/R, boost activated cutout, TSP 2.5 5.3l heads, Comp Cam 224/230 .600 with rockers, comp cams 1.75 roller rockers, dual Walbro 450's, Injector Dynamics id1300's, 4l80e w/3200 multidisk Circle D, trutrac w/3.73's, 3"DI/DO Magnaflow, tips through the roll pan, running COS3 Semi OLSD OS#12592618
    Lifetime Member darcy's Avatar
    Feb 2012
    Looks like the ethanol is working ok by that log. B3601 is set correctly.
    Why do you think it's lean? Are comparing Measured AFR to Commanded AFR - you can't do this if both one is pure gasoline and the other is an ethanol blend.
    I'd switch over to comparing EQRatio and Lambda then you are independant of the fuel composition.
    At WOT you command 10.0AFR, which for a stoich of 12.95 (30%ethanol) is EQratio of 1.3.
    You measure an AFR of ~11.2, which if set for stoich of 14.68, is EQRatio of 1.3
    So all is good on the fuelling side.
    Aug 2010
    Sorry, that log is after I changed the injector flow and both VE tables. That was so I could show the timing issue.
    Aug 2010
    Here are 2 logs where the tune was not changed. The only difference was adding alcohol.
    32.4% ethanol.efie10 fuel.efi
    Aug 2010
    After work today I messed with this a little. I got thinking about it, and maybe the fuel injectors are not flowing what they are suggested to flow. When I removed my old injectors, and installed these I populated the data with the online provided data ID offers, but my truck ran very rich. I had to lower the main VE tabke and boost VE table to get it to run properly. Well when I put in ethanol, it was not rich enough making me believe the injectors are not flowing what they are advertised to flow. I decided to take 5% off the IFR, and add 5% to the main VE and boost VE tables. It actually ran pretty close. I would assume that it should not have made a difference, but it did. Was I thinking right when I did this? Or should have have went in the other direction?
  1. E38 Flex Fuel: On the fly timing and fueling - anyone interested?
    By gmh308 in forum E37, E38 & E67 PFI ECM's
    Last Post: April 6th, 2019, 09:55 AM
  2. help with stumped fueling issue
    By JUSTASBC in forum Gen III V8 Specific
    Last Post: September 24th, 2014, 09:08 PM
  3. Replies: 21
    Last Post: July 7th, 2013, 10:31 AM
  4. Timing issue w/'02 Camaro tune on '95 LT1
    By schwoch1 in forum Gen III V8 Specific
    Last Post: March 17th, 2010, 03:11 PM
  5. COS3 fueling issue under boost
    By joeygc5 in forum Custom Operating Systems
    Last Post: December 28th, 2009, 05:07 PM
