Results 1 to 10 of 10
Thread: Update: Sep 29, 2014
    Default Update: Sep 29, 2014
    Both the V7.5 and V8 software was updated in this release, you must update both software packages.
    Release Notes:
    Known Issues:
    Check for known issues here.
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the "known issues" thread above.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 267
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 261
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Boot Block, Click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.66 (Sep 12
    , 2014)
    The EFILive Development Team
    Dec 2012
    Thanks!!
    Josh
    '04 GMC LLY
    Oct 2008
    Cheers mate
    VE Clubby 237/243@112 .618/.614
    New Member Calibratedpower's Avatar
    Nov 2012
    The designated bbx options is a great addition. For the cummins guys can we have the tunes listed as: Tune 1, Tune 2 and so on. I have customers who will think their tunes are wrong because the AutoCal does not display the tunes they ordered. Generic tune names will take care of this.
    Senior Member WyoFreeride's Avatar
    Sep 2011
    Thanks. Excited to see pg 5 of the rsa patching document too.
    2010 Dodge QCSB 6.7 Auto
    May 2010
    Thanks to fix the E67 issue
    looking forward for E92 new tables
    EFILive Tuner
    May 2009
    upon installing this software I noticed that the new style code disabling features for the CMC 2100 along with the see dealer timer option are not included and after installing the patch file to enable those features I can no longer open anything in the calibration tree (internal flash) on those OS's supported by the patch file
    Junior Member dodgeram082500's Avatar
    Nov 2009
    I noticed the loss of the CMC cal file patch as well
    2008 6.7 regular cab short bed 4x4 All mods by Terror Custom Tuning.
    Yeah sorry a few files got left out, we will do another update shortly.
    Nov 2005
    CMC Patch file have now been updated and are available in the first post here https://forum.efilive.com/showthread...-Beta-software
    Cindy
  1. Update: Sep 12, 2014
    Last Post: September 28th, 2014, 08:56 PM
  2. Known issues with Sep 12, 2014 release of the EFILive software and firmware.
    Last Post: September 26th, 2014, 04:43 AM
  3. Update:Sep 25, 2013
    Last Post: October 15th, 2013, 03:03 PM
