Results 1 to 10 of 12
Thread: blank serial number detected
    Jul 2014
    Default blank serial number detected
    I have a V2 and all software/firmware is up to date. My e38 ECM has just been programmed and returned to me. Now I need to do some slight tweaks to it. I'm able to read the calibration file just fine. The file is not locked or protected.
    The problem though is that the ecm serial number is blank. EFI Live tells me that I need to do a full reflash so it can assign a serial number. So I try - and it won't flash because the serial number is blank! I verified that it was programmed this way because the person who programmed it also sent me a copy of the calibration file and it shows the serial number to be blank. The only thing I know about the original programming is it was done using a V2 & a stream license.
    So how do I flash a new serial number onto the ecm if EFI Live wants a serial # first? Here's a copy of the output I get when I try to flash if it helps:
Name:	blank serial.JPG
    It tells me the ecm is ready for reflashing? And then the ecm is in an unknown state? The ecm originally came from a 2008 Silverado donor vehicle with a 5.3 that I had. It was then programmed as a 2009 so that it would work with a T43 trans controller in my 6L80e out of a 2009 Escalade.
    Oct 2008
    Edited, never mind.
    VE Clubby 237/243@112 .618/.614
    Which V7 software build version...?
    Jul 2014
    I updated over the weekend - I believe the v7 build # is 265 (it might be 262?) and my v8 build # is 260 (reads 259 though).
    I noticed another build was released yesterday on the 29th. I'll update to it and give it another try this afternoon.
    I'll post an update later with confirmed versions, firmware, and latest results flashing with new build.
    Yes, please post back here if you still see the zero serial number.
    Jul 2014
    Ok - I've verified that the versions I was trying with were v8.2.2.259 (260), v7.5.7.265, boot block 2.07.07 & firmware 2.07.66
    I just updated to v8.2.2.261 and v7.5.7.267. I retried anything I could think of - first picked 'test flash only' for calibration and full flash, tried activating/check license. Then tried all that again without "test flash only" selected. Tried with and without try alternate keys.
    Did not try assume lock may be faulty or try additional unlock strategies as I figured that the serial number is really the problem, not a potentially locked ecm. The status always tells me that the ecm is not protected.
    But no matter what - always get the same message: Blank serial number, try full flash.
    Unfortunately if the E38 has no serial number then full-flashing it with EFILive will not correct that. The memory that contains the serial number is not erased nor reflashed by the EFILive software even during a full-flash. That means you won't be able to license the controller. I don't know how the serial number could be erased.
    I'm not sure why the warning message shows up for an E38. It should only show up for older style controllers such as the LS1 and LB7 which can have their serial numbers updated during a full-flash.
    Quote Originally Posted by ducati2v View Post
    That unfortunately is the problem, the wrong year OS has been flashed in to it, doing so on these ECM's causes irreversible corruption of some sections of the ECM.
    EFILive will not let the user do this so I would suggest where you sent the ECM off to may have used GM's TIS or some other tuning software to do the 2008 - 2009 OS change.
    And unfortunately what Paul has said here is why the corruption (lost serial number) cannot be fixed, and he also said the 'repair via full flash' message should not show up on the E38 which is true.
    Jul 2014
    I was afraid that this was going to be the answer to my problem.
    Well, this is the second controller I've gotten. The first one he sent me was corrupted somehow and I was never even able to read it. I'll send this one back and see if he can update it with a modified calibration file that I send him.
    In the meantime, I'm thinking of getting another ECM. Will a 2010 e38 ecm (#12633238) with a 2010 OS be able to control a 2008 LC9 afm/non-vvt engine with a 2009 t43/6l80e trans?
    No, you need a 2008 ECM. The rule is you really need to keep everything married to the same year, annoying yes but unfortunately GM made changes that force this situation.
  1. Serial number
    By IdahoRob in forum Duramax LB7
    Last Post: June 2nd, 2014, 04:04 PM
  2. 01 LB7 blank serial 000000000000
    By Duramax01 in forum Diesel
    Last Post: April 8th, 2013, 02:20 PM
  3. Serial Number Blank, won't allow to reflash.
    By rpmspeed in forum Gen III V8 Specific
    Last Post: May 15th, 2012, 02:08 PM
  4. E38 Serial number
    By VEGASROBBI in forum E37, E38 & E67 PFI ECM's
    Last Post: March 9th, 2012, 04:30 PM
  5. Serial number: 000000000000
    By akafred in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2010, 10:41 AM
