Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Alternator control no BCM
  1. #21
    Mar 2015
    Thank you Tre-Cool. Can this be used with V8 as well. Once I make the .cax file, how do I access the alternator control in EFI Live?
  2. #22
    Feb 2006
    create it as a v7.5 cax, then use the in-built conversion tool to make it a v8 compliant file. I've still lazy and write them for 7.5, then convert later when needed.
    I haven't fully migrated to v8 for all my stuff yet.
  3. #23
    Same here.
  4. #24
    Mar 2015
    Quote Originally Posted by Tre-Cool View Post
    Save this to a text file and save with a .cax extension & place it in the C:\Program Files (x86)\EFILive\V7.5\Calibrations folder if using v7.5 with your os number for file name.
    [G1000]
    ; Description
    DESC.001 = Alternator Voltage Control: Indicates the vehicle is fitted with a regulated voltage control alternator and serial message duty cycle control from BCM is available, if disabled DC will be 100% when alternator is enabled.
    ; Seg Caption Major Minor Vis Dis 2D Grp
    VIEW = 7 "Voltage Control" "Alternator" "" 1 1 0 0
    ; Address(es) BitOff Bits Typ Inv
    ADDR = 1C0F04 0 8 SED 0
    ; Units Factor Offset Prec MinLimit MaxLimit MinUser MaxUser
    SI_SLOT = Units 1.0 0 0 0 256 0 256
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    SI_ENUM = "0=Not-Fitted,1=Fitted"
    ; Units Labels
    SI_COL = .
    IM_COL = .
    SI_ROW = .
    IM_COL = .
    [G1001]
    ; Description
    DESC.001 = Should only be enabled if Voltage Control is enabled. Indicates that the ECM can override the serial message alternator duty cycle to boost system voltage when required.
    VIEW = 7 "ECM Override" "Alternator" "" 1 1 0 0
    ADDR = 1E4720 0 8 SED 0
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    SI_ENUM = "0=Disabled,1=Enabled"
    IM_ENUM = "0=Disabled,1=Enabled"
    ; Units Labels
    SI_COL = .
    IM_COL = .
    SI_ROW = .
    IM_COL = .
    Tre-Cool, Is there a specific line in the text that I can change if I want the duty cycle to be lest than 100%?
  5. #25
    Feb 2006
    there might be a variable for it, there's a whole heap linked to that function block in the ecm. but understanding the conversion factor to work it out is a different matter. simple on/off switches are easy to follow.
  6. #26
    Mar 2015
    Tre-Cool, I tried the patch and I'm not sure what I could be doing wrong. I can only control the alternator with the DVT tab in the v7.5 scan tool. If I interpreted the voltage control description correctly, when I change the alternator voltage control from fitted to not fitted, it should make the alternator go to 100% duty cycle or full voltage in this case, but it does not. I even lose alternator control in the DVT tab. Hopefully I missing something here. I've tried quick flash and full flash of the ECM. Hope you can help.
  7. #27
    Feb 2006
    give these ones a shot. imo maybe changing the min duty cycle might bump it up along with the failure time. (the descriptions im stealing from HPT).
    [G1002]
    ; Description
    DESC.001 = Serial communications must be lost or duty cycle below minimum for this amount of time, before alternator duty cycle will be defaulted to 100%.
    VIEW = 7 "Default Time" "Alternator" "" 1 1 0 0
    ADDR = 1c0efe 0 16 UNM 0
    SI_SLOT = Seconds 0.00625 0 0 0 256 0 256
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    ; Units Labels
    SI_COL = .
    IM_COL = .
    SI_ROW = .
    IM_COL = .
    [G1003]
    ; Description
    DESC.001 = Maximum Duty Cycle requested by override voltage.
    VIEW = 7 "Override DC Max" "Alternator" "" 1 1 0 0
    ADDR = 1E46F8 0 16 UNM 0
    SI_SLOT = Percentage 0.003052 0 0 0 200 0 200
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    ; Units Labels
    SI_COL = .
    IM_COL = .
    SI_ROW = .
    IM_COL = .
    [G1004]
    ; Description
    DESC.001 = Minimum Duty Cycle used as limit for default action.
    VIEW = 7 "DC Min" "Alternator" "" 1 1 0 0
    ADDR = 1c0f00 0 16 UNM 0
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    ; Units Labels
    SI_COL = .
    IM_COL = .
    SI_ROW = .
    IM_COL = .
  8. #28
    Mar 2015
    [G1002]
    ; Description
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    ; Units Labels
    SI_COL = .
    IM_COL = .
    SI_ROW = .
    IM_COL = .
    [G1003]
    ; Description
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    ; Units Labels
    SI_COL = .
    IM_COL = .
    SI_ROW = .
    IM_COL = .
    [G1004]
    ; Description
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    ; Units Labels
    SI_COL = .
    IM_COL = .
    SI_ROW = .
    IM_COL = .
    No luck Tre-Cool. I was wondering, is it possible to make alternator control in the DVT of the scan tool active in the tune tool? I maybe oversimplifying, but is it possible to just copy and paste the code from the V7.5 scan to the v7.5 tune program?
  1. e38 alternator turn on
    By 68sstt in forum E37, E38 & E67 PFI ECM's
    Last Post: April 12th, 2011, 12:32 PM
  2. Turning on the alternator sooner
    By 68problemchild in forum Conversions / Aftermarket Parts
    Last Post: December 2nd, 2010, 02:52 PM
  3. Alternator not working after PCM swap, HELP
    By edwardzracing in forum Gen III V8 Specific
    Last Post: May 29th, 2009, 05:48 PM
  4. PCM's generator exciter output (alternator turn on signal)
    By joecar in forum Gen III V8 Specific
    Last Post: February 21st, 2008, 01:10 PM
  5. Alternator Monitoring
    By dbaxter_ss in forum General (Petrol, Gas, Ethanol)
    Last Post: June 8th, 2005, 02:21 PM
