I've got a 2000 Silverado with a turbo 4.8. Cos3 SD . what map should I use? I bought a new zr1 3.5 map and my tune is very rich...strange it will run decent in first gear only.. 4l60 auto... Eventually target boost psi will be 20..
Did you set the MAP sensor scaler/offset (so that KOEO MAP pid shows BARO)...?
No, I don't even know how to data log yet... I talked to a tuner and I was told the map I used has been know to not work good with my setup.
I did set map to 288 .....
Thanks for the help, Ive been searching and reading , its a lot to learn quickly.
Joe , I see your a mod....I'm a mod on Turbobuick.com........thanks for your hard work.
Hey, no worries, thanks... I'll come and visit TurboBuick.com sometime
Joe , I'm getting my tail kicked....lol....would you look over my tune? I can post up tomorrow. Come on by.....its and easy world living in the late 80's over there.....
Yes, post it here.
I'm running behind since we got my wife's Dad in the hospital, I'm trying to squeeze everything in between room visits and meetings with doctors, so it will take me a couple a few days (please bear with).
Sorry to hear that....I hope he gets better soon....
i cannot get the ifr calcultors to work,......i guess i dont know how to operate excell?
can someone calculater my IFR?
80 lb surefire injectors
68 psi vac line off at idle
200o silverado vac referenced fpr, with oem reture....
walbro 450 intank pump with 8 ga hot wire kit...
tia
for future searchers;
i found the zr1 3 bar map sensor here; http://www.jdpmotorsports.com/genuin...ensor-12592525
wired up a new connector and scalled map to; c6301 Tuning Data - Linear: 312.50 and Off-Set: -11.25
all is good....
