Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Update: Oct 5, 2014
  1. #21
    Mar 2009
    Quote Originally Posted by superwagon View Post
    I have always noticed that the percent different tab has not been correct since I started using efilive. For example my cummins 5.9 duration table shows 24.41% difference between stock and one of my tunes. If you do the math though stock is 2005 and modified table is 2653. this is actually a little over 32% increase over stock. I am not sure if this has been addressed in the past or not? Just figured I would mention it and see if its something I am doing wrong or if its being fixed at a later time.
    Like above poster said, to see the % differences you need to open the stock tune for the calibration, then your modified tune for the alternate. Then the differences will show correctly.
  2. #22
    May 2010
    Okay, I will take a look at that. I'm sure that is what is going on. I always have my modified tune opened first when comparing to stock.
    Thank you!
  3. #23
    May 2009
    I notice with this software release, (I've skipped a few updates) there is now a tuning option for "pro tuning" to be activated within the license screen in V8. can someone please explain what this entails, and how does one obtain such an activation code?!?!?!?!?!
  4. #24
    Nov 2005
    You can refer to this thread https://forum.efilive.com/showthread...Tuning-license
    (although we are keeping things low key for the moment)
    Cindy
  5. #25
    May 2009
    Cindy
    Thank you Cindy!
  6. #26
    Nov 2005
  1. Update: Jun 16, 2014
    Last Post: June 20th, 2014, 02:51 PM
  2. Update: Jun 13, 2014
    Last Post: June 15th, 2014, 01:24 PM
  3. Update:Oct 16, 2013
    Last Post: November 6th, 2013, 01:02 PM
