Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Update: Oct 5, 2014
    Default Update: Oct 5, 2014
    Both the V7.5 and V8 software was updated in this release, you must update both software packages.
    Release Notes:
    Known Issues:
    Check for known issues here.
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the "known issues" thread above.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 268
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 262
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Boot Block, Click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.70 (Oct 03
    , 2014)
    The EFILive Development Team
    Senior Member WyoFreeride's Avatar
    Sep 2011
    2010 Dodge QCSB 6.7 Auto
    Thanks.
    Dec 2012
    Josh
    '04 GMC LLY
    Dec 2006
    Installed and testing
    2007 LBZ 2011 LML Silverado Pickups
    2015 GMC Denali 3500 Dually Diesel Pickup
    2007 Dodge 6.7 Pickup
    Nov 2005
    Excellent, thanks guys (and Cindy!)
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Junior Member KDubya's Avatar
    Jun 2011
    Default Bad File Format
    This is what I got just after upgrading to the Oct. 5th release. Firmware was also updated.
    Thanks.
    Jun 2011
    Follow up, I went back to the same tune that gave me this error and it's fine now. This happened without closing the software. I will close and then re-try to see if it comes back.
    Oct 2008
    Thanks EfiLive team.
    VE Clubby 237/243@112 .618/.614
    Quote Originally Posted by KDubya View Post
    Thanks.
    Did you get that error when opening an existing file from your PC, or when reading a controller?
    If it was from opening an existing file, can you please send me the original file that you tried to open?
    Send to paul@efilive.com
  1. Update: Jun 16, 2014
    Last Post: June 20th, 2014, 02:51 PM
  2. Update: Jun 13, 2014
    Last Post: June 15th, 2014, 01:24 PM
  3. Update:Oct 16, 2013
    Last Post: November 6th, 2013, 01:02 PM
