Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Update: Oct 5, 2014
    Default Update: Oct 5, 2014
    Both the V7.5 and V8 software was updated in this release, you must update both software packages.
    Release Notes:
    Known Issues:
    Check for known issues here.
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the "known issues" thread above.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 268
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 262
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Boot Block, Click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.70 (Oct 03
    , 2014)
    The EFILive Development Team
    Senior Member WyoFreeride's Avatar
    Sep 2011
    2010 Dodge QCSB 6.7 Auto
    Thanks.
    Dec 2012
    Josh
    '04 GMC LLY
    Dec 2006
    Installed and testing
    2007 LBZ 2011 LML Silverado Pickups
    2015 GMC Denali 3500 Dually Diesel Pickup
    2007 Dodge 6.7 Pickup
    Nov 2005
    Excellent, thanks guys (and Cindy!)
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Junior Member KDubya's Avatar
    Jun 2011
    Default Bad File Format
    This is what I got just after upgrading to the Oct. 5th release. Firmware was also updated.
    Thanks.
    Quote Originally Posted by KDubya View Post
    Thanks.
    Did you get that error when opening an existing file from your PC, or when reading a controller?
    If it was from opening an existing file, can you please send me the original file that you tried to open?
    Send to paul@efilive.com
    Jul 2014
    Is there a development thread that has a changelog for the different versions?
    Nov 2005
    Quote Originally Posted by joshgabel View Post
    Change log is refereed to as release notes, the link is in the first post, and again here http://download.efilive.com/Document...se%20Notes.pdf. The release notes for each pre-release software build is added to the previous version of pre-release software release notes. The release notes process starts from a clean slate after pre-release becomes full public release software.
    Cindy
  1. Update: Jun 16, 2014
    Last Post: June 20th, 2014, 02:51 PM
  2. Update: Jun 13, 2014
    Last Post: June 15th, 2014, 01:24 PM
  3. Update:Oct 16, 2013
    Last Post: November 6th, 2013, 01:02 PM
