Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Known issues with Oct 28, 2014 release of the EFILive software and firmware.
    Default Known issues with Oct 28, 2014 release of the EFILive software and firmware.
    Currently known issues and possible workarounds for the Oct 5, 2014 release of the EFILive V7.5.7.269, V8.2.2.263 software and the V2.07.71 FlashScan and AutoCal firmware.
    Issue 1:
    Workaround:
    None. It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
    Issue 2:
    DSP5 upgrade is not available for LBZ/LMM controllers with operating system 12620015.
    Workaround:
    None.
    Issue 3:
    [Close] button in the [F8: Tools] window displays incorrectly when the option View->Small Buttons is selected.
    Workaround:
    None. Will be fixed in the next update.
    Issue 4:
    FPE (Fleece Performance Engineering) external PIDs do not log correctly if more than one FPE set of external PIDs is selected.
    Workaround:
    Only select one set of FPE PIDs to be logged in a single black box logging session.
    Do not attempt to transmit serial data to FlashScan that does not match the single selected FPE PID set.
    Issue 5:
    Cummins EDA (Enhanced Data Acquisition) black box logging returns incorrect results for PIDs if the display order of the PIDs is modified from the default EDA order in the [F5: BBX] window.
    Workaround:
    Do not modify the order of the selected EDA PIDs in the [F5: BBX] window.
    Select ALL the PIDs in the EDA group and don't add or delete any PIDs.
    Issue 6:
    E86B full flashing will not complete. ECM can only be recovered using TIS.
    Workaround:
    None. DO NOT USE FULL FLASH OPTION.
    Last edited by Blacky; February 9th, 2015 at 11:46 AM. Reason: Release updated to Oct 28, new issue added.
    V8 -> Tools -> Convert
    the Close button is displayed in a truncated manner:
Name:	V8 - Tools - Convert.png
    Thanks Joe,
    Looks like I never tested that window when the View->Small Buttons options was selected.
    Aug 2004
    If you Read out a calibration for ls1B in V8, and then click the EDIT tab and go to v7.5 it will not open the tune you just read out. Then going back to V8 will not let you see any of the details you just read out. The save as button is greyed out, and you have to re read the tune out.
    Exact instructions:
    1 open v8
    2 click read
    3 select ls1b and read ecm,
    4 "Don't save file first" click edit tab, open in v7.5
    5 try to get back to the tune you just read out will be impossible. V7.5 opens the latest tune you had, not the one you just read out.
    Aug 2004
    Not really an issue but more of space, when you are done executing a read or write of a diesel lm7 or ls1 ecm, it shows this, 4:37:47.428: Disconnecting ...
    14:37:47.820: CAN-VPW Bridge Deactivated
    14:37:47.823: Disconnected
    14:37:48.047: Loading generic configuration file: sae_generic.txt
    14:37:48.048: User defined calculated PIDs file: calc_pids.txt
    14:37:48.049: Enhanced configuration file: gm_enhanced.prn
    14:37:56.056: Done!
    Not sure why it would need to load those in as they are scan tool stuff right?
    Quote Originally Posted by wait4me View Post
    Exact instructions:
    1 open v8
    2 click read
    Thanks Jesse, I'll need to change the V8 software to ensure the file is saved before attempting to edit it using the [Edit with EFILive V7] button.
    14:37:56.056: Done!
    The tune tool software uses some info in those config files. Some of the data in those files is operating system specific. Re-loading the config files is required whenever the operating system of the currently loaded file changes. However, rather than compare the currently loaded file's operating system with the newly read file's operating system to determine if the files need re-loading, the V7 software simply reloads all the config files after a read or a flash.
    Aug 2004
    If the scan tool looses communication it no longer pops up a window stating that it is retrying to connect like it used to. Steps to see this,
    Plug in cable to obd and key on, connect to engine via green button,
    Then hit record button.
    Then unplug the obd2 cable with it still recording.
    It no longer complains of missing communication and keeps recording even though it isn't talking anymore.
    LS1B, E67, E92
    Jun 2011
    No timing calc in cmc csp5.
    New Member Calibratedpower's Avatar
    Nov 2012
    Is there anyway to raise or get rid of the 5 tune limit when setting up a quick setup black box flash file? We send out more than five tunes for the LML's and this would be a huge time saver.
    Scott
  1. Known issues with Sep 12, 2014 release of the EFILive software and firmware.
    Last Post: September 26th, 2014, 04:43 AM
  2. Known issues with Jul 19, 2014 release of the EFILive software and firmware.
    Last Post: September 12th, 2014, 12:12 PM
  3. Known issues with Jul 07, 2014 release of the EFILive software and firmware.
    Last Post: July 10th, 2014, 10:12 AM
  4. Known issues with Jun 21, 2014 release of the EFILive software and firmware.
    Last Post: July 3rd, 2014, 11:12 AM
