Results 1 to 5 of 5
Thread: Tuning Fuel Pressure Base Duty Cycle & P.I.D Control
    Junior Member LaydSierra's Avatar
    Sep 2011
    Default Tuning Fuel Pressure Base Duty Cycle & P.I.D Control
    Would anybody be interested in sharing some insight on this? I'm having what I've been told is referred to as rail surge. Basically where the actual rail psi constantly over/under shoots the desired. I know that reducing the % in the Base Duty Cycle table will help smooth this out but I don't know how far I can reduce it. Has anyone had any luck adjusting the P.I.D control to further smooth the actual rail psi?
    Senior Member garrettg.bpd's Avatar
    Jun 2013
    I have not played with P.I.D. control. But I have found that playing with Fuel Pressure Reg, Current Conversion can help.
    EFILive Beta Tester
    2006 DODGE RAM 2500 4X4 Industrial Injection R1 100HP Injectors and BAG-O-PARTS, ATS Exhaust Manifold, AFE 67MM Turbo and MANIFOLD
    Junior Member kyle027's Avatar
    Jul 2014
    Quote Originally Posted by LaydSierra View Post
    I was curious if you had gotten this problem fixed. My truck does this also. How much is your actual over and under shooting the desired?
    07 dodge 2500 5.9 cummins, 2inch level, modified air box, deleted exhaust, Efi live tuning, borg warner gov. Solenoid, billet transmission, 35 inch terra grapplers
    22 ram 2500 6.7 6 inch lift 22x12 welds, 37x13.5
    Nov 2013
    i had some problems on the dyno doing low load pulls. higher load and on the street pressure stayed more stable. what conditions are you having osculation at?
    Calibrator @ The Roadster Shop
    www.roadstershop.com
    Jul 2014
    Mainly in the lower load areas. Basically same as your problem.how much was your varying?
  1. Very odd fuel pressure table-Medium Duty-LBZ
    Last Post: March 28th, 2012, 05:46 PM
  2. Fuel Pressure Base Duty Cycle
    By FUBAR in forum Cummins 5.9L
    Last Post: January 21st, 2012, 04:21 PM
  3. Injector Duty Cycle??
    By Ponch in forum Gen IV V8 Specific
    Last Post: September 9th, 2007, 02:30 PM
  4. Injector Duty Cycle ?
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: April 9th, 2006, 05:12 AM
  5. TCC Duty Cycle
    By daveb in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 6th, 2006, 07:39 PM
