Thread: Can You Do a Cal Flash on Cummins?
    Member arinkuddy's Avatar
    May 2014
    Default Can You Do a Cal Flash on Cummins?
    I have been using the full flash without a problem but I wanted to speed up the process so I tried to use the Cal flash but i get a script file error. Is cal flash even available for Cummins or am I just missing somthing?
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Full Flash only.
    Dan's Diesel Performance
    www.dansdieselperformance.com
    May 2014
    Thanks! I figured that was the case.
    Unfortunately full flash is enforced by the ECM, there is no way around it.
    May 2014
    Too bad it would be pretty handy, but I'm glad I have the control that's there ha.
    It takes about 18 minutes to flash one with the dealer tool, so it could be worse.
  1. OS Change, Cal size, Full flash?
    By EagleMark in forum Gen III V8 Specific
    Last Post: October 31st, 2012, 10:36 AM
  2. Cal-Flash
    By 2006Cummins in forum Cummins 5.9L
    Last Post: January 20th, 2012, 05:37 PM
  3. Unable to Cal Flash PCM
    By yeller in forum General (Diesel)
    Last Post: March 20th, 2011, 09:41 AM
  4. Out of range cal in a GM flash?
    By MaxPF in forum Allison 5 & 6 Speed
    Last Post: February 27th, 2011, 07:06 AM
  5. BBx Cal Flash?
    By 8100 Power in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 16th, 2011, 11:20 AM
Tags for this Thread
