A little update on what I have done , I put a LY6 in a 2006 Colorado, I am using a E67 with a 2009 Colorado with a 4L60E out of a truck.
I have a couple of issues...
First the Trans Files
Truck runs great with a 2006 Trailblazer T42 file and Os in the TCU , But when I a put a 2009 Colorado T42 File in it , It does not want to shift and goes erratic when it goes into boost.
The Shift Indicator and Speedo will not work in when the Trailblazer File is in the T42 ...
I need the Speedo and Shift indicator segment swapped into the Trail blazer file , Can anyone on here help me with that
Secondly is the fans, I can command them to turn on with the scan tool , but the ECU will not turn them on ? I have checked all the settings and they should be coming on but they are not.
I have attached all my files , If anyone thinks they can help . Thanks...
