Results 1 to 3 of 3
Thread: Timing/AFR problem only when in manual mode T43
    Jun 2008
    Default Timing/AFR problem only when in manual mode T43
    I'm experiencing a weird scenario that I can't quite figure out. When I have my car (09 cts-v) in manual mode at part throttle, I experience a rapid jump in timing and the AFR leans out completely. I'm thinking something in the tune is telling it to pull timing, because the values never go below my "minimum final timing" values. This does not happen in regular auto mode.
    Now I believe this to be called Fast Torque Exit with hpt. Is this parameter in the tune somewhere?
    Jun 2008
    Thanks for the help on this...I ended up just using Hp tuners to turn off fast torque exit, and it fixed it....
    May 2010
    I have the same problem in almost all pulley E67 i tuned
    the car is pulling timing when the torque increase
    so i hope this table will be added to E67
    EFILive Tuner
  1. Transmission Manual Mode
    By SkinnyPedal in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 7th, 2014, 12:29 PM
  2. Fuel tables different in auto mode versus tap shift with an e38/t43
    By whypave in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 30th, 2014, 03:23 PM
  3. T43 problem please help
    By yajokn in forum Gen IV V8 Specific
    Last Post: February 2nd, 2014, 10:38 AM
  4. Gear Indication and Manual mode questions
    By spoolinsteve in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 13th, 2011, 08:01 PM
  5. 4L60E Manual Mode Downshifting 3-2 & 2-1
    By TRANNYMAN in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 3rd, 2008, 08:11 AM
