Results 1 to 7 of 7
Thread: DTC help
    Oct 2014
    Default DTC help
    I know there are several posts out there for this kind of stuff but i am posting because I have not found an answer that helps me yet. When I first installed my EFI live on my 08 6.7 cummins, I had zero issues. suddenly, randomly i will get an OH ding stating see dealership, maintenance required but no CEL. when i hook up my tuner it displays a DTC of $0280. Now it comes up every single time i turn my truck on and about 20 minutes into a drive. Dealerships dont have a clue since the code relates to a 7th cylinder...... any ideas? I have tried calling the rep who sold this to me and his advice was "this just happens with some of the tuners" and did not have a real answer so i have tried calling and so far am not happy....
    When you see DTC P0280, find the diagnostic troubleshooting chart (from the service manual) and work thru it to isolate the cause...
    also, borrow an advanced scanner (from Autozone) and see if it sees the same DTC.
    Either:
    - the DTC is for real, and there is a problem with #7 injector circuit;
    - the DTC is not for real, the problem might be with the ECM;
    - the DTC is not for real, the problem might be with scantool, it is reading some remnant stuff from the ECM.
    Senior Member KhakiCummins's Avatar
    Sep 2011
    What is all done to the truck? DPF Delete? EGR Delete? If so, how was the EGR deleted? (i.e. EGR unplug only, EGR and TV unplugged, EGR plugged in and tied out of the way) The more info you can provide about exactly what is done to the truck, the easier it will be to help diagnose the problem.
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
    This sounds like the known issue with the overhead chime on 6.7 deleted trucks. Your tuner is correct, unfortunately there is no complete fix for every truck at this time. EFILive is busy working on a fix, but unfortunately some trucks just do this.
    Let's be clear, you have 2 issues: 1) $0280 issue is an issue with your AutoCal device configuration ($0280 is no vehicle detected) which should be resolved by using the latest software and 2) the overhead chime which is a calibration issue.
    Nov 2005
    I agree with Eric, sounds like the overhead chime to me, however given you are an AutoCal user any solution needs to come from the Tuner who wrote the tunes for your AutoCal.
    There are a range of additional parameters available on select operating systems that in some cases 'cure' this issue and in others delay the issue so that it only occurs once every 360 minutes per drive.
    These calibrations are available for your tuner to manually download and install in the Cummins 6.7L forum section. Once they have done that, they can re-write your tune.
    Cheers
    Cindy
    Oh, he meant error $0280... lol
    Oct 2014
    Thanks, I'll try to figure out how to download the newest software. I'm not very tech savvy when it comes to this stuff. Thanks for the help guys, just glad it isnt anything too big
  1. DTC's from v2 to lap top and cures to DTC's
    By 68problemchild in forum FlashScan V2
    Last Post: October 2nd, 2010, 04:08 AM
  2. Dtc p0430
    By ItzNota in forum Gen III V8 Specific
    Last Post: October 8th, 2008, 05:11 PM
  3. DTC I've never seen
    By RPM Motorsports in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 18th, 2008, 11:20 PM
  4. Help With DTC's
    By TAQuickness in forum General
    Last Post: April 26th, 2006, 06:10 AM
  5. help with DTC
    By WicketMike in forum General (Petrol, Gas, Ethanol)
    Last Post: February 6th, 2006, 11:21 AM
Tags for this Thread
