Results 1 to 10 of 14
Thread: 411 AC and cooling fan issue
    Jan 2009
    Default 411 AC and cooling fan issue
    I'm using an Express Van 411 (12212156 OS, low resolution crank) to control a C4 L98 engine. The thing is up and running great except one issue. When AC is requested, only one fan runs. The second fan kicks in (as normal) when coolant temp reaches 195. But by then AC head pressure is causing the compressor to go off line. Once the second fan does kick in, head pressure drops and compressor runs forever. Anyone have any idea how to make an AC request run both fans?
    Aug 2006
    Did you wire in an A/C Pressure sensor and install the correct "System" segment into your tune? It can't operate the fans based on A/C pressure if there is no sensor.
    Jeff
    Jan 2009
    Yes, the pressure sensor is in the system. I know nothing about a "System" segment. Can you explain?
    Aug 2006
    Can you post your tune?
    Jeff
    Quote Originally Posted by Yellow05C6 View Post
    In the tunetool, look down the left hand side, you will see "folders" for Engine, Engine Diagnostics, Transmission, Transmission Diagnostics... etc... the last "folder" is System
    ( the "folders" are segments )
    Jan 2009
    I believe I have successfully added the tune file. Silly of me not to understand "System", the file is set to Y-Body with low resolution crank. When scanning, the ECM correctly reports against the Air Conditioner Pressure Sensor Voltage PID.
    Aug 2006
    Try this and see if it helps.
    Jeff
    Jan 2009
    Wow, it works. But when I compare your mod to my original file it comes back as zero changes. Can you tell me what you did?
    Aug 2010
    The A/C System configuration was changed from ground activation (A/C request = grounding a 12V circuit) using Low & High A/C Pressure Switches, to ground activation using an A/C Pressure Sensor.
    The parameter is not available in EFILive, which is why you will see no difference during a comparison of the two tunes.
    Aug 2006
    If I tell you, I'm going to have to kill you. Taz is correct. The parameter is not in the "As Purchased" EFILive software.
    I'm glad it worked out.
    Jeff
  1. E39 - Cooling Fan Controls
    By Overkill in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 24th, 2014, 09:37 AM
  2. E38 pwm cooling fan control
    By vette5797 in forum Conversions / Aftermarket Parts
    Last Post: December 24th, 2009, 05:07 AM
  3. E38 Fan Patch issue.
    By johnsZ06 in forum E37, E38 & E67 PFI ECM's
    Last Post: January 24th, 2009, 08:18 AM
  4. Well guys I'm baaaaaaaaaaaaaack!!! Cooling fan OS problems.
    By ssvolvo in forum Gen IV V8 Specific
    Last Post: May 1st, 2008, 10:21 PM
  5. misfire issue after 411 swap
    By makoskey in forum Vortec V6/V8 Specific
    Last Post: December 21st, 2007, 09:05 AM
