Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 411 AC and cooling fan issue
  1. #11
    007 stuff
    Some parameters are not mapped out in EFILive.
  2. #12
    Jan 2009
    I'm glad I do not have to die...thanks for the help. Another question if you do not mind: I'm helping a friend with a 411 mod also to a C4 only his car runs a ProCharger. (In fact the car is already running with COS3, we are just dealing w/ nit-noid stuff like A/C.) If I re-start his tune by loading the file you modified for me into his car and then import the 3-bar COS, will this A/C feature follow into the new file; or, will the feature get lost in the transition?
    tks again
    Wes
  3. #13
    Aug 2006
    The original tune you posted is a 12212156 OS. If your buddy's car is running 02020003 then just do a segment swap of "System" from the Mod1 tune to his. The 02020003 OS is based off of the 12212156 OS.
    Jeff
  4. #14
    Aug 2010
    ... 007 stuff ...
    Too funny ! Not really "secret squirrel" stuff. Believe the Tunercat crowd has had this for years ... HPT added it awhile back also.
    Taz
  1. E39 - Cooling Fan Controls
    By Overkill in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 24th, 2014, 08:37 AM
  2. E38 pwm cooling fan control
    By vette5797 in forum Conversions / Aftermarket Parts
    Last Post: December 24th, 2009, 04:07 AM
  3. E38 Fan Patch issue.
    By johnsZ06 in forum E37, E38 & E67 PFI ECM's
    Last Post: January 24th, 2009, 07:18 AM
  4. Well guys I'm baaaaaaaaaaaaaack!!! Cooling fan OS problems.
    By ssvolvo in forum Gen IV V8 Specific
    Last Post: May 1st, 2008, 09:21 PM
  5. misfire issue after 411 swap
    By makoskey in forum Vortec V6/V8 Specific
    Last Post: December 21st, 2007, 08:05 AM
