Results 1 to 4 of 4
Thread: $0331 Error reading 2014 Impala
    Jul 2011
    Default $0331 Error reading 2014 Impala
    Hey guys
    I have a customer who's getting error $0331 reading their 2014 Impala using the Autocal I sent. Its preloaded with the E39 ECM read protocols, I didn't see E39A listed which this computer may be if it isn't the regular E39 but I'm pretty sure its an E39 12651994
    Any suggestions? I'm using the software that I downloaded in July when I got started with EFILive, and its read out 12 and 13 Impalas fine so far.
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    Make sure you update your software to the latest version! There have been updates since then!
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Nov 2005
    As Kory said, please update your software, and then firmware for both your FlashScan and the customer's AutoCal to the latest pre-release software, dated October 5. https://forum.efilive.com/showthread...ate-Oct-5-2014
    E39A is a separate controller in the V8 Scan and Tune software. To ensure you do 'detect' the right controller, I recommend that after you update your software that you open V8 Scan and Tune software, then in the [F5: BBX] -> [F3: Tune] menu select open and open the Options_GM_Gas2.txt options file. Uncheck any controllers you do not require leaving you with E39A.
    From there you have a number of options to send updated configuration files to your Customer for him to update on his AutoCal, the Quick Setup is probably the easiest method to use.
    Cheers
    Cindy
    Jul 2011
    Quote Originally Posted by cindy@efilive View Post
    Cheers
    Cindy
    Thank you Cindy, after opening that options file I now see the E39A tune option, and I've sent a quick setup file to my customer. Will report back if any issues, otherwise thank you for your support
  1. Anyone have stock tune files for 2014 IMPALA SS ???
    By Chuck CoW in forum Gen IV V8 Specific
    Last Post: December 26th, 2013, 08:44 AM
  2. error $0331 is back again
    By gymratt40 in forum AutoCal
    Last Post: July 29th, 2012, 04:29 PM
  3. $0331 Error E38
    By Mike@Vengeance in forum AutoCal
    Last Post: November 18th, 2011, 10:48 AM
  4. dreaded error $0331 when attempting reflash
    Last Post: July 30th, 2011, 08:19 AM
  5. Error $0331
    By RULEMKR in forum AutoCal
    Last Post: January 26th, 2011, 09:39 AM
