Results 1 to 10 of 11
Thread: Map sensor problem in efi live scan tool
    May 2011
    Default Map sensor problem in efi live scan tool
    I have been longing some data in the efi live scan tool and have the map pid selected to read and log data in the dashboard but the needle never moves on the map section of the efi live dashboard. I have no dtc for map. The needle should move whether the pid is imperial or metric correct?
    In the scantool goto the Data tab, and move the slide bar (across the bottom) and see if the MAP pid shows values.
    Which MAP pid are you using...?
    Which year/model/vehicle...?
    Can you check in your tune file if the MAP DTC's are enabled/disabled...?
    Post screenshots of your dash and of the Data tab.
    Is the replot button (looks like a star/snowflake, at the bottom) red...?
    May 2011
    This is a 2002 5.3 in a 92 Camaro.
ID:	17622   Click image for larger version.
    May 2011
    Mil light
    May 2011
    On the data tab it is reading numbers but on the dashboard the numbers do not move
    Which V7 build version (do Help->About)...?
    On the PIDs tab set all pids to Metric, on the Dash, select the Metric version of each pid (on each gauge do rightclick->Metric), save the Dash and try again.
    Is you MAP sensor connected ok (physically and electrically)...?
    Quote Originally Posted by zayne0 View Post
    Mil light
    Look at table C6002.
    Did you click the Monitor button (yellow) or the Record button (red)...?
    Try the record button.
    May 2011
    Switching the gauges to metric made it work!
  1. Scan Tool Problem
    By TFZ_Z06 in forum General
    Last Post: June 25th, 2012, 02:37 AM
  2. Problem with EFILive Scan Tool V7.5.4 (Build 6)
    By Kevin Doe in forum General
    Last Post: September 18th, 2008, 04:43 PM
  3. Scan tool problem NEED HELP
    By yellowC6ohio in forum Gen IV V8 Specific
    Last Post: April 7th, 2008, 04:11 PM
  4. No live data on EFI scan tool
    By Drummer in forum FlashScan V2
    Last Post: February 18th, 2008, 12:05 AM
  5. EFI live scan tool question
    By esco35m in forum General (Petrol, Gas, Ethanol)
    Last Post: June 14th, 2007, 05:20 AM
