Results 1 to 5 of 5
Thread: 2015 ZL1 E67 unfamiliar ecu
    May 2009
    Default 2015 ZL1 E67 unfamiliar ecu
    I just read a 2015 ZL1 and got a message that the ecu was not recognized and to send a copy to tech support. Here a copy file. Any chance of getting this ASAP as this car is leaving for Turkey Friday.2015 ZL1 Conv as rec.ctz
    If you update to the latest software version on our website you should find this is supported.
    http://www.efilive.com/latest/cat/do...e-oct-05-2014/
    Aug 2010
    2015 E67 OS 12658816 is indeed supported ....
    Apr 2007
    Does anyone have a stock EFILIVE tune for this 2015 ZL1 Camaro ?? The tune file depot is gone and I need a stock tune to compare it to another tuner that screwed up this tune with HP
    OS # is 12658816 an E67 ECM OR does anyone know now where we can get STOCK tune files in EFILIVE ? THKS
    Jul 2003
  1. E67 ECU can not be read or written.
    By B19coupe in forum FlashScan V2
    Last Post: December 14th, 2015, 04:11 AM
  2. Camaro ZL1 E67 SERIAL DATA???
    By 400ss in forum E37, E38 & E67 PFI ECM's
    Last Post: September 21st, 2014, 07:42 AM
  3. Where to get e67 ECU pins
    By snax in forum E37, E38 & E67 PFI ECM's
    Last Post: February 29th, 2012, 01:28 PM
  4. Is there any way to run two DBW TBs on an E67 ECU?
    By E67boostquest in forum E37, E38 & E67 PFI ECM's
    Last Post: December 21st, 2011, 08:51 PM
  5. gmpp e67 ecu ls376/480
    By nutte in forum E37, E38 & E67 PFI ECM's
    Last Post: August 29th, 2011, 07:48 AM
