Results 1 to 3 of 3
Thread: 5.3 manual swap
    Member ippielb's Avatar
    Jun 2010
    Default 5.3 manual swap
    got someone who swapped a manual transmission into their truck, need the tuning changed over, i have never swapped segments before in the transmission, i will get more info on his truck,
    2004 silverado 5.3l i was going to use the 2006 silverado tune from tunefiledepot as there's a 4.8 manual and 5.3 auto with same operating system, but the manual tune file wont open.
    I do not want to under take this if it's over my head, i havent touched a gas vehicle a few years, the dirtymax is where i spend my time.
    2006 Chevrolet Silverado 2500hd 6.6l LLY Duramax
    NADP Race Transmission & NAPC Built Transfer Case
    AFE Stg 2 Intake Snow Performance Methanol Injection
    FASS 150gph Titanium Series Pump EFI Live
    PPE Race Valve & PPE Fuel Rail Fitting
    BD Manifold 3" AFE Ceramic Downpipe 4" Straight Pipe
    Yukon Grizzly Locker Mag-Hytec Cover & Traction Bars
    Leveling kit & 33" Hankook RT03 18" XD Addict Rims
    HID's all around LED taillights and 3rd brake light
    Autometer Fuel Pressure, Boost, and Pyro Gauges
    Jun 2010
    Okay so I guess it is a turbo 400 transmission not a manual. But a guy needs to use the manual tune because the t400 transmisssion is not electronically controlled. Has the blue red PCM connections
    Aug 2006
    Most guys who do that type of trans swap just delete the trans codes. If you use a manual tune the PCM will be looking for input from the CPP switch, which the truck won't have anyways. Unless he uses a VSS equipped TH400, he won't have a speedo either.
    Jeff
  1. Segment swap causing different results than manual copy / paste
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 27th, 2014, 02:55 PM
  2. 2000 Pontiac TA WS6 - Manual Tranny to 4L65E Swap - Tune Questions
    By WarEagle1 in forum Gen III V8 Specific
    Last Post: February 5th, 2014, 03:43 AM
  3. os calibration swap 06 megacab california manual
    By relentless addiction in forum Cummins 5.9L
    Last Post: September 24th, 2013, 03:22 AM
  4. Manual 4l80 swap question
    By phantom in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 25th, 2011, 12:34 PM
  5. 411 5.7 vortec swap switch to manual tranny
    By jomobco in forum Vortec V6/V8 Specific
    Last Post: January 11th, 2008, 12:45 PM
