Results 1 to 6 of 6
Thread: Logging DMA PIDs on Duramax fails
    Default Logging DMA PIDs on Duramax fails
    The Duramax DMA PID logging problem can be cured by downloading and installing the attached configuration file.
    Unzip it into the folder: \Program Files\EFILive\V7\Configuration\
    See this post for the description of the problem.
    http://www.dieselplace.com/forum/showthread.php?t=78625
    Dec 2005
    Thanks for all the hard work that you guys have done for us. Everything was worth the wait.
    04.5 2500HD LLY EC/LB
    14 Sonic RS Sedan
    GM Certified Technician
    President of the 'I killed an ECM' club
    Lifetime Member Max Power's Avatar
    Nov 2005
    Does this also have the corrected diesel calculated timing pid in it?
    09 LMM Duramax
    Quote Originally Posted by Max Power
    Yes, it is now calculated as "({SAE.RPM}*{GM.MAINBPW}*3)/500000"
    Senior Member Racehemi's Avatar
    Nov 2005
    I just installed the new config and verified my PID's are working correctly!
    Thanks for making my day, you guys rock, as always
    04 2500, LLY/A, 4x4, CC, SB, 285 Toyo's, Amsoil lubes, Access Roll-up Tonneau, ATS Stage 2 trans, ATS 5 Star Converter, Bilstein's, Caltracs bars, Cognito Braces, EFILive, Kennedy Diesel Custom Tuning, Kennedy Diesel headlight harness, Kennedy Dual Lift Pump/Filter combo, Prodigy brake controller, Spa DG 211, Trippin Cyclops overhead gauge mount, , TTS 4" Exhaust, TTS Xtreme Beta, Amsoil Ea filters, Banks CAI
    Quote Originally Posted by Racehemi
    Thanks for saying nice things, but I should not have released a dud file to begin with.
    Just glad you guys picked it up so fast so I could get it fixed before it confused too many people.
  1. logging pids
    By aaronr in forum Black Box Logging
    Last Post: February 18th, 2009, 11:46 AM
  2. BB logging pids
    By fire0021 in forum FlashScan V2 BB Logging
    Last Post: January 30th, 2009, 12:47 PM
  3. Issues logging E38 PIDS
    By thunder550 in forum FlashScan V2 BB Logging
    Last Post: April 28th, 2008, 05:52 PM
  4. More PIDs in E67 for BB logging?
    By scdyne in forum Black Box Logging
    Last Post: January 30th, 2008, 12:22 PM
  5. Best PIDs for Logging Dry Shots?
    By Beer99C5 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 23rd, 2006, 06:28 AM
